Old 08-31-2019, 08:23 PM   #1
Twocollies
Question shaking front end
I was returning home from a car show this afternoon when the front end started shaking. sort of scared me. I pulled over and checked the front wheels. I grabbed the wheel to see if there was any play. There was none. I looked around at the perches, drag link shocks. every thing seem fine. I started the model A up and drove the rest of the way home with no problems.
Has anyone experienced this and what could it be?
Twocollies is offline   Reply With Quote
Old 08-31-2019, 08:29 PM   #2
History
History's Avatar
Default Re: shaking front end
Search for "Death Wobble" on this site.
History is offline   Reply With Quote
Old 08-31-2019, 08:31 PM   #3
Synchro909
Synchro909's Avatar
Do a search on "Death Wobble" here. It has been discussed MANY times.
BTW, what oil do you use??!
Here's one result to that search.
https://www.fordbarn.com/forum/showt...t=death+wobble
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 08-31-2019, 10:18 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
The first thing I'd do is make sure the toe-in is 1/16" and make sure the front wheel bearings aren't too loose. My temporary front axle is worn very sloppy, but I've never had the death wobble.
Old 09-01-2019, 12:06 PM   #5
springerpete
springerpete's Avatar
check for tightness in the wishbone on the axle and at the back end of it.
springerpete is offline   Reply With Quote
Old 09-01-2019, 04:21 PM   #6
john in illinois
john in illinois's Avatar
This is often the cause. There is a reproduction rubber ball socket. If you have this it is suggested replacing with original.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 09-01-2019, 04:30 PM   #7
sphanna
sphanna's Avatar
I had a death wobble in my coupe. Could not stop it from occasionally happening until I replaced the rubber ball mentioned in post #6 with an original system. This affected the caster and the original system fixed it. Went for several yers until I sold it.. never a problem again.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
