08-19-2019, 07:46 PM | #1 |
ignition switch wiring
Have I wired the ignition switch correctly? Does it make a difference?
08-19-2019, 07:52 PM | #2 |
Re: ignition switch wiring
It's simply an on-off switch so makes no difference.
Be careful the screws in the back don't contact the gas tank and short out. I added electrical tape to the tank surface. I added liquid tape to the screws as an added insulator. You can also adjust the collar so you have more clearance in the back. .
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
08-19-2019, 07:59 PM | #3 |
