Old 08-08-2019, 10:08 PM   #1
51504bat
51504bat's Avatar
Default Head light switch for a '54 converted to 12v
Getting ready to completely rewire my '54 Ranch Wagon and convert it to 12 volts. I've read conflicting opinions on using the stock '54 6 volt headlight switch vs. using a 12 volt one from a '56/57. From what I can tell the 12 volt switch will accept the knob assembly from the '54 switch and the 12 volt unit will install with no mods where the 6 volt switch was. C&G said the '54 switch should work fine but I'm a little concerned about how the dash light dimmer rheostat in the 6 volt switch will work with 12 volts. Am I worrying about nothing or should I go with the 12 volt switch?
