Old 06-24-2019, 07:29 AM   #1
Cecil/WV
Cecil/WV's Avatar
Default '48 Ford horn-missing!
I have a '48 Ford that is nearing completion and I bought it in pieces. There is something missing that goes under the horn ring to make contact with the wire coming up through the steering shaft. I have the spring. There is provision for a wire to be connected to the ring. What is missing. I can't find a picture of this breakdown. Thanks!
Cecil/WV is offline   Reply With Quote
Old 06-24-2019, 08:59 AM   #2
34pickup
34pickup's Avatar
Default Re: '48 Ford horn-missing!
If I have it right, the wire comes up and screws to the horn ring and when you press the horn ring, it makes contact with the steering column, grounding it out, and making an electrical connection complete which makes the horn blow.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 06-24-2019, 09:20 AM   #3
RalphM
RalphM's Avatar
The wire goes through a plate that attaches to the back of the horn button.
File Type: jpg BC261D94-CC47-4D84-BD91-56FA0449E91B.jpg (33.4 KB, 75 views)
RalphM is offline   Reply With Quote
Old 06-24-2019, 12:26 PM   #4
drolston
drolston's Avatar
The tricky part is that sponge rubber thing that cushions the horn ring. The replacement I got for my '41 was so fat and stiff I could not get the horn ring installed with it in place. I cut the thickness down by almost half, and it works okay.
Old 06-24-2019, 12:42 PM   #5
FortyNiner
FortyNiner's Avatar
These horn connections are head scratchers until you find the attachment point for the wire to the horn relay - this is the one that runs through the steering column. As drolston pointed out, the insulator foam rubber piece is a key part.
Before you start assembling, make sure that you have a good ground for the column - this eliminates some frustration during testing.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 06-24-2019, 06:13 PM   #6
Cecil/WV
Cecil/WV's Avatar
Where is the contact point to complete the connection. My new wire coming up through the steering shaft has an end not compatible with fastening to the button.
Old 06-24-2019, 07:04 PM   #7
meric42
meric42's Avatar
Your horn wire should look like this one listed on eBay
https://www.ebay.com/itm/11A-14308-1...wAAOSwjjddAzm8
The horn button connection is the screw terminal in the left of the photo. The bullet connector is the one that connects to the loom at the bottom of the steering column.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 06-24-2019, 11:30 PM   #8
RalphM
RalphM's Avatar
Connection is under plastic portion of button, makes contact from wire to ground.
Old 06-25-2019, 05:47 PM   #9
Cecil/WV
Cecil/WV's Avatar
After looking at the picture posted by RalphM, I did some more research and found that there are 2 different wires listed for '48 and I had the wrong one. I cut my wire and put an end on with an eye and figured out how it works, put it together and it works great!! Thanks to everyone for help and suggestions!
Old 06-25-2019, 08:27 PM   #10
RalphM
RalphM's Avatar
Yes, some horns have the small center button, and some have the large chrome ring. I never thought about it but I’m sure they are designed differently
