Old 05-28-2019, 10:27 AM   #1
lignell
Default 39 ford
could someone please tell were the resistor is located thank you
lignell is offline   Reply With Quote
Old 05-28-2019, 10:43 AM   #2
Tom/SC
Tom/SC's Avatar
Default Re: 39 ford
The ignition coil resister is located inside the car, on the inside firewall, up from the steering column. I hope this helps .
Tom/SC is offline   Reply With Quote
Old 05-28-2019, 10:49 AM   #3
19Fordy
19Fordy's Avatar
Default Re: 39 ford
Here's the 40. I believe 39 is the same. The maroon thing is the E brake handle.
Old 05-28-2019, 11:09 AM   #4
marko39
Default Re: 39 ford
on the 39 you will find it on inside firewall mounted next to the headlamp circut breaker or fuse.
marko39 is offline   Reply With Quote
Old 05-28-2019, 11:45 AM   #5
19Fordy
19Fordy's Avatar
Default Re: 39 ford
Here's a better look at the circuit breaker and the resistance unit in a 40.
Old 05-28-2019, 02:03 PM   #6
lignell
Default Re: 39 ford
thank you
Old 05-28-2019, 02:17 PM   #7
Kube
Super Moderator
Kube's Avatar
Default Re: 39 ford
Here's a photo of a proper '39 resistor / circuit breaker in the correct position.
Old 05-31-2019, 02:45 PM   #8
lignell
Default Re: 39 ford
thank you
