Old 05-27-2019, 09:23 PM   #1
shew01
shew01's Avatar
Default 6’2”
I’m 6 ft 2 in tall, and I got my first chance to sit in the driver seat of a 1930 coupe this evening for a few moments. (I didn’t get the opportunity to actually drive the car.) I was surprised at the snug fit. Is the seat adjustable? Does the Tudor or Fordor have any more room for the driver than the coupe?
shew01 is offline   Reply With Quote
Old 05-27-2019, 10:49 PM   #2
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
Default Re: 6’2”
Tudor has more room. You can easily modify the seat mount to move it back 3 inches.
Good Luck
dansluck is offline   Reply With Quote
Old 05-27-2019, 11:29 PM   #3
The Master Cylinder
The Master Cylinder's Avatar
Default Re: 6’2”
I'm 6' 2" and ~195 lbs. I have a '30 Fordor Sedan. I moved the front seat back 3" and bent the shifter 1-2" to the right to give me more leg room. Still plenty of leg room in the back seat.
I have driven Coupes, Roadsters and PUs and they are all just too tight for my liking.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 05-28-2019, 07:09 PM   #4
eagle
eagle's Avatar
Default Re: 6’2”
I'm 6' 4" 210lbs 36" inseam. I've tried a pickup, its dangerous! Can't get my legs to cooperate in the confinement. My Fordor was very tight too. I moved the seat back, made a big difference. Was driving one day and was having trouble with the shifter too close to my leg, got disgusted with it and pulled over, grabbed the shift lever about 6 inces from the floor and bent it over where I wanted it! No trouble since.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 05-28-2019, 10:34 PM   #5
BillEbob
BillEbob's Avatar
Default Re: 6’2”
When shopping for my Model A I discovered that the Victoria has the widest doors (I can now get my size 13 shoes in the car! My fused back didn’t take kindly to the original seats so I bolted in some angle iron and installed a set in a set of Honda Prelude seats. I now cruise around in comfort!
Given a couple hours I could restore it to stock setup if I were to sell the car.
BillEbob is offline   Reply With Quote
Old 05-29-2019, 01:59 PM   #6
31Abone
31Abone's Avatar
Default Re: 6’2”
Cabriolet has wide doors 68c I removed package tray and adjusted seat back..lots of room .
31Abone is offline   Reply With Quote
Old 05-29-2019, 02:33 PM   #7
CHuDWah
CHuDWah's Avatar
Default Re: 6’2”
Dunno about Tudors and Fordors but I had an early-30 Sport Coupe that had adjustable seat - I'd guess regular coupes do as well. I'm 6' and with the seat all the way back, I could reach the pedals but any farther back would have been a stretch.
CHuDWah is offline   Reply With Quote
Old 05-29-2019, 07:53 PM   #8
jax55
jax55's Avatar
Default Re: 6’2”
I have a 31 sport coupe and am 6'2" around 200. I have the seat as far as back possible without modification, I slide across the seat to get my feet and legs in then slide under the wheel. It's tight, but I can make it work.
I also sat in a PU as though I was driving....Nope, not for me.
jax55 is offline   Reply With Quote
Old 05-30-2019, 06:11 AM   #9
chap52
chap52's Avatar
Default Re: 6’2”
Have a 30 Tudor. I am 6'4', 225#. I used the longer brackets and still moved the drivers seat back a couple of inches by relocating those extended brackets. Plenty of legroom both in front and back.
It's not a question of "can I drive it", but of will I be comfortable and able to SAFELY operate the pedals? Chap
chap52 is offline   Reply With Quote
Old 05-30-2019, 07:35 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
Default Re: 6’2”
Billebob,
Can you post some pictures of the Honda seat installation in your 190A. I need to do this.
Bob Bidonde
Old 05-30-2019, 08:20 PM   #11
KGBnut
KGBnut's Avatar
Default Re: 6’2”
Yes, with the '30 Standard Coupe some people have removed the package tray and moved the seat further back. You gain 3 - 4 inches.
My Coupe is unmodified. I am 5'11" and have the seat adjusted all the way back.
Good luck,
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 05-31-2019, 11:28 AM   #12
LeroyM
LeroyM's Avatar
Default Re: 6’2”
I'm 6"4 230lbs and have no issues in my 31 coupe. My car is a "hotrod" as some might call it. What I did was removed the package tray and used the middle seat out of a late 80's early 90's Chrysler minivan. I used an adjustable seat rails kit from speedway. There is plenty of room in a coupe if you're not afraid of change.
LeroyM is offline   Reply With Quote
