Old 05-21-2019, 10:15 AM   #1
TJ97tim
TJ97tim's Avatar
Default Towing your A
Hi All,
Looking for pointers on towing your A.
What trailer size do you use?
Where are your strap points?
Thanks
Tim
TJ97tim is offline   Reply With Quote
Old 05-21-2019, 10:41 AM   #2
BillCNC
BillCNC's Avatar
Default Re: Towing your A
Hi Tim,
I towed my car with the body cocked to one side to a VIN inspection. I used a car hauler from U-haul for like $35 for half a day. They gave me (4) straps that went over the tires keeping the car from moving forward's or backwards. For added safety, I used 4 tie-down's, one on each corner of the frame keeping it from moving sideway's. The Tie-down's were completely unnecessary but were added to keep the law from wasting my time to have a look and asking a bunch of pointless questions.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 05-21-2019, 08:19 PM   #3
whirnot
whirnot's Avatar
I went all out and have never regretted it. I had Cargo Mate build one for my A's. It is a 16 foot enclosed, Vee nose. I had it made 6 inches taller than standard to fit a sedan. I had Etrack built into the floor on 4 foot centers.
And I used no rivet exterior and matched the Cole of my tow vehicle. It is perfect.
The only thing I would change is put the Etrack a couple inces closer together. It is just inside the A wheels and if not perfect the tire is sitting on the Etrack trim. No big deal, just bugs me.
Easily pulled with a half Ton pickup.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 05-22-2019, 12:16 AM   #4
Ed Wendell
Ed Wendell's Avatar
Tim,
Ours is a touring car so I have no problem with an open trailer. We use our sons BobCat trailer, a little over kill for the A but it is free.
I put D ring plates on the deck and I use "tire basket" ratchet straps. Car did not budge on the 570 mile trip to Reno/Sparks last year.
Ed
Ed Wendell is offline   Reply With Quote
Old 05-22-2019, 08:43 AM   #5
Jordan
Jordan's Avatar
I use a tow dolly & also use the over-the-tire straps without issue.
But when I use a trailer we use 2 straps on the front axle & 2 on the back.
Cowtown A's
Jordan is offline   Reply With Quote
