Old 05-09-2019, 11:57 AM   #1
nailbender
Default No oil pressure [8BA]
This on new rebuild, done at a shop.[this shop is OK done other work for me] Started with electric gauge checked with mech. no pressure. pulled the gauge only drips from the tube. Changed oil again, same. Pulled the pan and pump [looks new as the invoice said]. The engine fired right up and sounds good. With the pan off I can see assemble lube here and there. Put air up the pump hole via rubber stopper no bubbles from my oil pressure tube. Plain C maybe D. Any ideas where to look next, or how check things further.
nailbender is offline   Reply With Quote
