Old 04-20-2019, 07:19 PM   #1
Branded
Branded's Avatar
Default Stocking Dealers for Drake
Anyone have a recommendation for a stocking dealer for Out of Stock Bob Drake.
I’m needing a Headlight Wire Harness wire harness 01A-11653.
For a 40 Sedan
Branded is offline   Reply With Quote
Old 04-20-2019, 07:40 PM   #2
JSeery
JSeery's Avatar
Default Re: Stocking Dealers for Drake
There are several venders that have wire harness parts and some of them manufacture their own.
Old 04-20-2019, 07:46 PM   #3
35fordtn
35fordtn's Avatar
Drake doesn’t produce his harnesses. As mentioned above many vendors stock that harness.
35fordtn is offline   Reply With Quote
Old 04-20-2019, 07:48 PM   #4
TJ
TJ's Avatar
Check with Sacramento Vintage Ford. They make harnesses to factory specs and should match up to the Drake harness. The other place to check is Bauer Electronics in Bend, Oregon. They also make harnesses and supply a lot of the V-8 vendors.
TJ is online now   Reply With Quote
Old 04-20-2019, 09:05 PM   #5
51504bat
51504bat's Avatar
I believe that Joe's Antique Auto in MA is a Drake dealer. Another possibility is YandZ in Redlands, CA Not as cheap as Drake but top notch quality.
Old 04-20-2019, 09:11 PM   #6
Branded
Branded's Avatar
I bought the dash harness from you, was hoping you had the headlight harness also. Was told via E Bay message your out of stock for 7 weeks.
Old 04-20-2019, 09:12 PM   #7
Branded
Branded's Avatar
Thanks , I believe I found the headlight harness on their website. I’ll call them Monday to confirm.
Old 04-20-2019, 09:16 PM   #8
35fordtn
35fordtn's Avatar
Branded,
Yes I’m out too for a few weeks. FYI Sacramento Vintage Ford harness won’t match your current. Personally I’d try Joes, C&G or Early V-8 Sales in SC
Old 04-20-2019, 09:18 PM   #9
Branded
Branded's Avatar
Branded,
Yes I’m out too for a few weeks. FYI Sacramento Vintage Ford harness won’t match hardly anyone else’s. Personally I’d try Joes, C&G or Early V-8 Sales in SC
Thanks for the heads up, Macs also has one on eBay but I’m not sure if it’s compatible with what I bought from you.
Old 04-20-2019, 09:20 PM   #10
35fordtn
35fordtn's Avatar
Branded check your PM’s I messaged you back
Old 04-20-2019, 09:29 PM   #11
Branded
Branded's Avatar
Thank you, I’ll wait to hear from you Monday.
Dave
Old 04-21-2019, 10:19 AM   #12
Tony, NY
Maybe try Rhode Island Wiring Service. They have been around a long time.
http://www.riwire.com/
Tony, NY is offline   Reply With Quote
Old 04-22-2019, 05:05 PM   #13
35fordtn
35fordtn's Avatar
Thought I'd elaborate on what I said in Post #8.. Sacramento Vintage Ford, Rhode Island, etc all make excellent harnesses.
The only reason for stating they won't "match" is simply by appearance. Heck, my 1933 in my avatar has a Sacramento Harness in it and fits the bill.
The cloth covering and wrapping on different manufacturers harnesses will vary in appearance only. I always recommend for appearance reasons to use the same source for main harnesses so that the transition from one to the next will match.
Thought I'd post this as to not make it seem there is a functionality issue when there is NOT.
Old 04-22-2019, 06:41 PM   #14
TJ
TJ's Avatar
Michael, thanks for the clarification.
Old 04-22-2019, 09:02 PM   #15
mhsprecher
mhsprecher's Avatar
Tyree Harris supplies exactly what you need. 804-556-5200
mhsprecher is offline   Reply With Quote
Old 04-23-2019, 01:10 AM   #16
john stimac
john stimac's Avatar
Little Dearborn Parts in Minnesota 612-331-2066
john stimac is offline   Reply With Quote
Old 04-23-2019, 07:48 AM   #17
George
George's Avatar
Tyree Harris in Virginia can supply you with what you are looking for.
George is offline   Reply With Quote
Old 04-23-2019, 10:09 AM   #18
philipswanson
I have better luck with Carpenter than "Back Order Bob".
philipswanson is offline   Reply With Quote
