Old 04-10-2019, 10:28 PM   #1
all american boy
all american boy's Avatar
Default Distributor Cap and Rotor Duraspark Conversion
Will this Duraspark cap,adapter and rotor just go on and work on a point type
distributor?
'Has racing made you a millionare?'
'Yes it has.Before I was a multi-millionaire.'-Quote
all american boy is offline   Reply With Quote
Old 04-12-2019, 08:11 PM   #2
darrell
Default Re: Distributor Cap and Rotor Duraspark Conversion
it fits but ive never tried it on points
darrell is offline   Reply With Quote
Old 04-12-2019, 09:08 PM   #3
all american boy
Thank you.
Let's wave our magic wand and say it does work with points.
Step 2 would be to get a point eliminator kit.
It is back burner project.Just always wondered if it would work.
Old 04-12-2019, 09:32 PM   #4
fordor41
fordor41's Avatar
2 piece ford cap will work on '57 to at least '75 or so. Make sure you get cap(top), adapter(center section) and rotor. also will need corresponding plug wires. Reason Ford went with the larger cap is so plug wires are farther apart and eliminates cross firing. Also new cap has "male" plug wire connector so that eliminates moisture collecting as on the small cap. I used this set-up on my '81 302 w/ mid '70's point dist.
fordor41 is offline   Reply With Quote
Old 04-12-2019, 10:42 PM   #5
all american boy
'2 piece ford cap will work'
Thank you.Nice to know after all these years!
We ordered for a '78 Ford pickup 351M to get a Duraspark setup.
We will keep them on the shelf until it's time to upgrade that distributor.
It will be awhile.
