Old 04-09-2019, 03:32 PM   #1
DD931
DD931's Avatar
Default Champion No. 20 Spark Plugs
I have just acquired some Champion No. 20 spark plugs. Without an extremely close examination they appear to be suitable for a Model A. They are two-piece, but do not have a copper top. Can anyone offer some insight?
DD931 is offline   Reply With Quote
Old 04-09-2019, 04:16 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Champion No. 20 Spark Plugs
Is it a Champion W20? If so, it is a bit hotter than a stock Champion 3X. Works OK on a Model A. A bit hotter than a W18.
I have 6 new ones here, if anyone would like to run them in their engine. You can have them for $5 each + postage (~$6.50).
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 04-09-2019, 04:49 PM   #3
DD931
DD931's Avatar
No - just 20. Only have two ribs at the top - the rest is smooth. Not like the W14 I have which has ribs all down the insulator except where the numbers are.
Old 04-09-2019, 05:10 PM   #4
M2M
M2M's Avatar
M2M is offline   Reply With Quote
Old 04-09-2019, 05:16 PM   #5
M2M
M2M's Avatar
Old 04-09-2019, 05:22 PM   #6
M2M
M2M's Avatar
Old 04-09-2019, 05:37 PM   #7
JoeCB
JoeCB's Avatar
I see an I-H-C logo, that is International Harvester Co. Plugs for the old farm tractor guys. I don't know how the heat range would compare for Model A use... but suggest might be in BIG demand for them with the old tractor restoration crowd.
Joe B
JoeCB is offline   Reply With Quote
Old 04-09-2019, 07:09 PM   #8
DD931
DD931's Avatar
M2M - That's it. No brass top like the first pic.
Old 04-10-2019, 02:03 AM   #9
M2M
M2M's Avatar
Do you have these in new undamaged condition in their original boxes?
Old 04-10-2019, 08:18 AM   #10
DD931
DD931's Avatar
Sorry - no. They are used in a bag with others. Insulators appear stained although I haven't tried to clean them. Points look almost new. Nice and clean in the combustion area. And I only have three!! Very much like your pics.
Old 04-10-2019, 09:32 PM   #11
1crosscut
1crosscut's Avatar
To clean the stain from the insulator material soak the plugs in Oxalic Acid (wood bleach) available at any hardware store. Will clean off any rust and doesn't affect the steel or printing.
Works very well.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 04-11-2019, 04:38 AM   #12
Bob-A
Bob-A's Avatar
Smile Re: Champion No. 20 Spark Plugs
I checked my Feb. 1936, Champion Spark Plug Service Type Selector for Passenger Cars. And no number 20 plugs are listed. The #20 plugs must be for commercial, farm or industrial use.
Bob-A
Bob-A is offline   Reply With Quote
Old 04-11-2019, 07:22 AM   #13
DD931
DD931's Avatar
Thanks for all the helpful comments. You've given me the info I was looking for. FordBarn comes through as always!!
Old 04-11-2019, 08:30 AM   #14
CWPASADENA
CWPASADENA's Avatar
Model A spark plugs have a longer reach which puts the electrodes down into the combustion chamber.
The # 20 plugs as you have shown have shorter reach that puts the electrodes up higher and may be even into the threaded part of the spark plug hole.
I would stay with a plug with longer reach that designed to fit the Model A head.
JMO,
Chris W.
CWPASADENA is offline   Reply With Quote
