Old 03-31-2019, 01:24 PM   #1
jwaldrich
jwaldrich's Avatar
Default Need a source~~~~~!!
I need a source to purchase a carb spacer that will fit my 322CI 1940 LaSalle equipped with a carter and sometimes Stromberg Carbs.
Can anyone point me to a seller of this item?
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
Old 03-31-2019, 02:45 PM   #2
34PKUP
34PKUP's Avatar
Default Re: Need a source~~~~~!!
If you haven't done so already, why don't you check on the Cad/LaSalle owners site.
Or bite the bullet and make or have one made if it's that important.
Then also try any vendor that sells speed equipment.
Such as Summit racing-------
https://www.summitracing.com/search/...s&N=4294916476
34PKUP is offline   Reply With Quote
Old 03-31-2019, 03:35 PM   #3
tubman
tubman's Avatar
Search "eBay". I've found a lot of stuff on there from people who use it to sell stuff from their regular businesses, not the auction option. They're "Search" option takes a bit of time to figure out, but it works pretty well.
Old 03-31-2019, 07:58 PM   #4
Cool Hand Lurker
Cool Hand Lurker's Avatar
Could you post a photo of the base gasket or the carb bottom side so we know exactly what you need? Maybe something from another make car that uses the same carb would fit.
Cool Hand Lurker is offline   Reply With Quote
Old 03-31-2019, 08:12 PM   #5
Fordors
John, what is the need for a spacer? Might not be what you are after but some will make one from phenolic or even plywood as an insulator to prevent fuel percolation. Phenolic is rigid, plywood less so, if you use that be careful tightening the carb down. I would think commercially available spacers are made for more common carburetors.
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 04-01-2019, 11:13 AM   #6
jwaldrich
jwaldrich's Avatar
I have gas boiling in the float bowl and I can't go 2 miles without a vapor lock hence the need for a spacer. Phoenolic would be great. Where might I find phoenolic stock?
John from Kapowsin
T&A Guy
Old 04-01-2019, 11:40 AM   #7
4dFord/SC
4dFord/SC's Avatar
Google is your friend.
4dFord/SC is offline   Reply With Quote
Old 04-01-2019, 11:41 AM   #8
Cool Hand Lurker
Try this, not cheap but you can get the right size piece.
https://www.amazon.com/Phenolic-Shee.../dp/B00CPRFMK4
Old 04-01-2019, 11:48 AM   #9
jwaldrich
jwaldrich's Avatar
I've "googled" until my eyes crossed.
John from Kapowsin
T&A Guy
Old 04-01-2019, 11:49 AM   #10
jwaldrich
jwaldrich's Avatar
I'll go this route if nothing else turns up.
John from Kapowsin
T&A Guy
Old 04-01-2019, 02:44 PM   #11
Bob C
How about this. https://www.summitracing.com/parts/ctr-85-030/overview/
Old 04-01-2019, 09:01 PM   #12
1952henry
1952henry's Avatar
Macmaster carr would probably have phenolic stock. Just have to have it machined.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 04-02-2019, 07:33 AM   #13
JM 35 Sedan
JM 35 Sedan's Avatar
I bought a couple of carb spacers from this company....Cool Carb Technologies
John
Old 04-02-2019, 08:29 AM   #14
STEVE O
STEVE O's Avatar
Last resort have your local wood worker make you one out of wood ( Let him chose which works best for the application ). They work great!
STEVE O is offline   Reply With Quote
Old 04-02-2019, 08:53 AM   #15
ABento
I bought the phonolic sheet from Mc Master Carr, a hole saw on the drill press and a jig saw worked just fine, you may also create an aluminum heat shield to go with it.
ABento is offline   Reply With Quote
Old 04-02-2019, 11:06 PM   #16
T Scott
Made one out of teak, scavenged from a local boatyard. My 37 LaSalle liked it. Carb stays cool.
T Scott is offline   Reply With Quote
