Old 03-07-2019, 02:38 PM   #1
Paul Howes
Default time the engine
I have a 1931 A with a B engine in it. water pump, distributor, manifold and etc. are all A parts. How do I time the engine?
Florida Paul
Paul Howes is offline   Reply With Quote
Old 03-07-2019, 02:44 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: time the engine
If you are using the model A timing cover and distributor You would time the same as the model A.
Old 03-08-2019, 12:57 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
If you use an A distributor, but the front timing gear cover is B, then move the spark lever to the mid position and use the timing pin as normal.
Old 03-08-2019, 08:40 AM   #4
Patrick L.
Patrick L.'s Avatar
The key is the front cover as the 'B' cover timing pin hole allows for 9º advance. To set the timing to 'A' specs with the 'B' cover the timing lever would have to be set down 4 or 5 clicks and the timing then set.
Old 03-08-2019, 08:48 AM   #5
jhowes
The car is running great now so pull the distributor cover and watch where the rotor is when the timing pin goes in the cam indent. This will tell you if you have a B or an A timing cover. Then do as the rest have said on here. your brother Jack. your cell still rings BUSY all the time.
jhowes is offline   Reply With Quote
Old 03-08-2019, 09:04 AM   #6
jwilliams81
jwilliams81's Avatar
This may help too:
http://www.fordgarage.com/pages/timingcovers.htm
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
