Old 02-26-2019, 07:30 PM   #1
gavinnz
Default Bought three Flathead V8 engines yesterday
I went to see a friend today and after a few hours of looking at old engines and talking we did a deal and I have bought all his Ford flathead V8 engines. I plan to build one good one from the three to power a 1930's New Zealand built wooden barrel back, V stern speedboat I have to restore.
I would love some help getting the engines years and types nailed down.
1. "the car engine" Pulled from a twin spinner car. Number "RE2 92" stamped on block face.... 24 bolt. Has on 8BA cast on one head and EAC on the other. (head swaped for Merc head??) Made in Canada. Side dizzi.
2. "the truck engine" Pulled from a bus. Number "RE2 71" stamped on block, both heads have 8RT on them, so truck? Made in Canada. Side dizzi.
3. "Rust ball engine" 24 stud, water outlet in middle of heads, front dizzi mount. Built in bell housing. Only good for parts if I am lucky. Seriously rusty.
Any clues there? I was figuring 1952 for 1 and 2??
Regards
Gavin
New Zealand
gavinnz is offline   Reply With Quote
Old 02-26-2019, 08:34 PM   #2
cas3
Default Re: Bought three Flathead V8 engines yesterday
there is a very good engine id thread running now. go back a day or so, "block id" i believe is the title. good luck with the motors, and whats a "twin spinner" ?
Old 02-26-2019, 08:40 PM   #3
V8ER
'51 Ford grille is a twin spinner.
V8ER is offline   Reply With Quote
Old 02-26-2019, 08:43 PM   #4
cas3
i had a 50 once, i guess i had a single spinner and never knew it!
Old 02-26-2019, 09:19 PM   #5
alanwoodieman
rustball engine appears to be late 38 thru 41 engine. 24 stud, pencil ledge above timing cover, different years have slight variables
alanwoodieman is offline   Reply With Quote
Old 02-26-2019, 09:21 PM   #6
alanwoodieman
look on here for the boat motor vs industrial motor thread, you need that motor!
Old 02-26-2019, 09:26 PM   #7
gavinnz
Than for the tip, I had seen that and I tried to message the seller to see if he would sell the exhaust manifolds but I got an error message.
I can make my own wet exhaust manifolds anyway... old ones will need work especially if they had been in salt water.
Old 02-26-2019, 09:29 PM   #8
gavinnz
I will try and put up another photo of the front s the distributor drive might help date it too....
Old 02-26-2019, 10:52 PM   #9
Mike in AZ
Mike in AZ's Avatar
Welcome to the ‘Barn. Post some pics of your project as you progress. Sounds like fun. Mike
Mike in AZ is offline   Reply With Quote
Old 02-26-2019, 11:03 PM   #10
gavinnz
Thanks for the welcome Mike!
Old 02-26-2019, 11:19 PM   #11
Tim Ayers
Twin pulley water pumps is big truck.
The one in the middle is leading me to believe it's a '48 truck motor due to the 8BA style block but use of head studs. This was the only series of 8BA style blocks that used studs.
Old 02-26-2019, 11:29 PM   #12
gavinnz
That's really interesting!! I was wondering why it had studs and not bolts on that block... it came from a 1952 bus but who knows what it was fitting from new... you might have it there.
Old 02-27-2019, 12:42 AM   #13
gavinnz
Went mad and bought 5 books on rebuilding and hotting up the flathead! They should be here in a few days.... no substitute for the right information!
Old 02-27-2019, 01:37 AM   #14
gavinnz
The "truck motor" with the studs, is Canadian made and has "C1BA" cast in razed letters on the back of the engine just behind the right head above where the bell housing goes on... a web page listing Canadian production as that casting meaning 1951....
I wonder if the Canadian engines used the studs longer than USA built motors?
Or mine have been changed??
Old 02-27-2019, 02:09 AM   #15
gavinnz
The motor with the bolts "the car motor" is also "C1BA" block casting number....
Old 02-27-2019, 04:22 AM   #16
gavinnz
I love learning new things so I am having great fun here... I have spent all day and all yesterday reading about Flatheads. Lots to learn! I was just reading about fitting the crab type distributor on the later 8BA block.... I like that idea. I might have to hunt up the parts I need. Some of which I might be able to get off my "rust ball" engine?? Was that a crab originally? Fingers crossed the cam might be OK in there also.... if I can use that one for the conversion..?
Old 02-27-2019, 05:29 AM   #17
gavinnz
I think I have found more clues on the "ball of rust" engine...
It fits this description of a Model 29A engine built from 1942 to 45....
"Crab-Style distributor, water outlet on center of cylinder head, passes pencil test"
Old 02-27-2019, 06:43 AM   #18
corvette8n
corvette8n's Avatar
http://www.vanpeltsales.com/FH_web/f...85to100mid.htm
This may help identify your early block, lots of good info on this site.
Welcome to the barn.
Old 02-27-2019, 07:22 AM   #19
skidmarks
skidmarks's Avatar
rusty motor looks like the distributor itself is cast iron
skidmarks is offline   Reply With Quote
Old 02-27-2019, 08:21 AM   #20
alanwoodieman
could be a LUCAS distributor as they were on some engines during the war years from Canada
