Old 02-18-2019, 04:08 PM   #1
DD931
DD931's Avatar
Default Shock fluid/oil
I just bought a set of rebuilt shocks at a fair price. They do not say "Houdaille" on them and the rebuilder says they are repops from maybe the 70's. Made in Chicago. He says he used 80/90 wt. gear oil as fluid. In principal, that seems to be OK, but I'm interested in your comments! What's the viscosity of proper shock fluid?
DD931 is offline   Reply With Quote
Old 02-18-2019, 09:12 PM   #2
Beater
Beater's Avatar
Default Re: Shock fluid/oil
I use straight 30 engine oil in mine
Beater is offline   Reply With Quote
Old 02-18-2019, 09:44 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Use thicker oil to make up for wear.
Old 02-18-2019, 10:15 PM   #4
Flathead
Flathead's Avatar
The right fluid depends a lot on how tight the internal clearances are. If the rebuilder says 80/90 I would go with that.
Flathead is offline   Reply With Quote
Old 02-18-2019, 11:41 PM   #5
daveymc29
daveymc29's Avatar
Is there aa chance the thicker oil will slow down the leaking? I have two sets that came from a reputable rebuilder who is no longer with us. Both sets were filled by him and leaked from day one. The oil is about the consistency of hydraulic jack fluid and gave a fair ride but it is getting about dry now, so I have been reluctantly contemplating going with the heavier oil or tube shocks. I haven't had the best of luck with rebuilt shocks, all leak upon installation and a short ride. I have heard here that new shocks now don't leak if you spend enough money, but have never actually seen a shock that doesn't leak. Thanks for any suggestions.
daveymc29 is offline   Reply With Quote
Old 02-19-2019, 03:20 AM   #6
denniskliesen
denniskliesen's Avatar
Dave I've read a lot of leaking shock posts in the past. It just didn't make sense to try and rebuild old worn out or froze up shocks that I've also read leaked coming out the door from a dealer when they were new. Granted I paid a lot of money for a set of Stipe shocks, they are bone dry after 2 years. Hopefully they will stay that way. Too bad I didn't know you had never seen a shock that doesn't leak when we were at the MAFCA convention last year, I could have shown you mine.
denniskliesen is offline   Reply With Quote
Old 02-19-2019, 05:57 AM   #7
old31
I have a set of Brattons (bill stipe) that I have had for 4000 miles and they have been leak proof for that time. Yes they are expensive.
Old 02-19-2019, 10:50 AM   #8
Ruth
I don't think the shocks Bratton's sells are from Bill Stipe. Bratton's shocks are 'factory sealed'.
