02-16-2019, 11:33 PM | #1 |
line going to timing gear cover 46 V8
One of Tom's customers brought his A hot rod to the shop on a trailer so he could get help with questions about the body. The engine is a 46 V8. On the timing gear cover, drivers side there is a tube it is cut off that goes in to the casting on left of top. Right now it is just a stub of tube being held in with a flare nut. What might it be? And were did it go to? He hadn't noticed it and was not sure himself. I looked at the Green book, but not knowing what it was did not find it.
Thanks
02-16-2019, 11:43 PM | #2 |
Re: line going to timing gear cover 46 V8
On a 38ish it goes to the from the dizzy to intake manifold between the the 5-6 cylinder.
1938, It is a smaller line then the 1/4" fuel copper line. Vacuum to distributor brake. Later through the timing cover. . |
02-17-2019, 12:08 AM | #3 |
Ok good, it not an oil line and will not be needed for his application. Thank you very much, that is good news that I will pass on to him
02-17-2019, 11:17 AM | #4 |
as stated its the vacuum for the distributor. if he has the stock intake manifold the line is available from the vendors. if you need to make a custom line, those are special fittings that crimp the line when tightened up to seal. only place i found any was nos at 3rd gen auto
02-17-2019, 11:54 AM | #5 |
It has custom headers, aluminum intake, 2 97's, Edmond heads and Edmond air cleaners. The distributor has been updated too so no vacuum needed, hole will just get plugged.
Thank for the information.
02-17-2019, 01:22 PM | #6 |
Note: Bad day at the ranch, LOL. This is all kook-kook. Last edited by JSeery; 02-17-2019 at 08:15 PM. |
02-17-2019, 03:09 PM | #7 |
jseery, are you drivin in england, or drivin in america?
02-17-2019, 06:02 PM | #8 | |
Does this mean you don't bother reading the opinions of others?
Alan |
02-17-2019, 06:43 PM | #9 |
I'm with JSeary. That is a return line from the bypass filter. No kidding.
02-17-2019, 06:49 PM | #10 |
JSeery's picture is the oil filter line, agreed, and is on an earlier engine with the football distributor. The engine in question is a '46 with the rabbit ear distributor.
Alan |
02-17-2019, 06:52 PM | #11 |
On my '46 to '48, 59 series engine, the stock timing gear cover has a threaded hole on top left side that accepts a vacuum line, and the opposite end of this line connects in the intake manifold. There is a cast or drilled hole inside the timing gear cover that completes the vacuum connection through a small hole in front of cover to a small hole in back of the crab/rabbit ear type distributor. This completes the connection to the vacuum brake inside the distributor.
The oil filter return line was connected to a threaded fitting on the left sidewall of the oil pan.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 02-17-2019 at 08:39 PM. |
02-17-2019, 07:14 PM | #12 |
"Does it look like it is a factory type of connection into the timing cover" Yes it is inline with a rib cast in the cover. Not for a banjo fitting, small flare nut and maybe 1/4OD tube.
02-17-2019, 08:00 PM | #13 | |
Think you can see the line from the timing cover to the base of the carb in these photos. Last edited by JSeery; 02-17-2019 at 08:25 PM. |
02-17-2019, 08:16 PM | #14 |
02-17-2019, 08:36 PM | #15 |
See image for location.
02-17-2019, 08:50 PM | #16 |
02-17-2019, 09:47 PM | #17 |
its ok jerry, i never screw up, but i understand some folks do once in a while. we seldom get a chance to catch you though !
02-18-2019, 12:09 AM | #18 |
I thought I was wrong once, but I was mistaken!
Alan |
02-18-2019, 12:21 PM | #19 |
It is okay . . . sometimes we jump to a "confusion conclusion" and once that cements itself into our reptilian brains, it takes a huge amount of work to dislodge it! (Some would claim a complete mental reboot is required). Ask my ex wife how I know such things! LOL
