Old 02-04-2019, 03:52 PM   #1
Cecil/WV
Cecil/WV's Avatar
Default '48 Ford hood springs
Anygood tips on how to spread the springs on the hood to remove in install new??
Cecil/WV is offline   Reply With Quote
Old 02-04-2019, 05:02 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: '48 Ford hood springs
I've read that to INSTALL them people put washers between the coils to EXPAND the spring. Would probably work just as well to remove the spring. FWIW
Paul in CT
Old 02-04-2019, 06:17 PM   #3
Darrell S
Darrell S's Avatar
Her is an old thread. The washer method seems easiest.
https://www.fordbarn.com/forum/showt...rs+hood+spring
Darrell S is offline   Reply With Quote
Old 02-04-2019, 06:29 PM   #4
TJ
TJ's Avatar
I have installed them with a brake spring tool
Old 02-04-2019, 07:04 PM   #5
bigdoor
1did my 41with washers
bigdoor is offline   Reply With Quote
Old 02-07-2019, 07:34 AM   #6
corvette8n
corvette8n's Avatar
I used a couple of ratchet straps to spread them and inserted cotter pins between the coils(I had a coffee can full of the same size pins.)
Old 02-07-2019, 08:49 PM   #7
cmbrucew
cmbrucew's Avatar
You can use a floor jack to spread them.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 02-08-2019, 12:09 PM   #8
Cool Hand Lurker
Cool Hand Lurker's Avatar
It is not hard to remove the whole hinge, then let it collapse. The spring will come off a lot easier then.
Cool Hand Lurker is offline   Reply With Quote
Old 02-09-2019, 08:18 AM   #9
alanwoodieman
on sort of the same vane, do the new springs make the hood open up more? being new to these 48/52 trucks, I find the hood/over fender access a little lacking
alanwoodieman is offline   Reply With Quote
Old 02-09-2019, 11:29 AM   #10
GoCatGo
GoCatGo's Avatar
This is a "for what it's worth" heads up. I changed the weak hood springs on my '48. I bought the replacements supplied by all the regular vendors, part #91A-16789. They were longer then the original springs, therefore the hood only opened half way up.
GoCatGo is offline   Reply With Quote
Old 02-09-2019, 06:11 PM   #11
alanwoodieman
thanks gocatgo
