01-19-2019, 07:44 PM | #1 |
1940 Ford Brakes
I am rebuilding the Brake Cylinders on my 40 Ford.
I do not drive the 40 very often and the Brake Cylinder Pistons seize up. My question is: A) Can silicone grease be applied to the pistons without causing any issues/harm? B) Can a DOT5 Brake Fluid be used to replace a DOT3 Brake Fluid in the 1940 Ford without causing any negative issues? C) Would using a DOT5 Brake Fluid be a solution to reduce Brake Cylinder Piston seize up? THANKS !!! |
01-19-2019, 09:02 PM | #2 |
Re: 1940 Ford Brakes
You posted in a forum used for questions "To The Editors". Very few people read this (except the editors) and even fewer respond. You should post here: https://www.fordbarn.com/forum/forumdisplay.php?f=4
Welcome to fordbarn. Charlie Stephens |
01-19-2019, 10:08 PM | #3 |
I am new to this site so I will try your suggestion. THANKS |
