Old 01-13-2019, 03:52 PM   #1
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default LED headlight replacement for 6v. sealed beams
Is there an LED replacement unit available for 6v. sealed beam units? I have a burnt out sealed beam unit on my 51 ford and it would be a good time to make the switch, Thanks in advance. Barry
Barry B./ Ma. is offline   Reply With Quote
Old 01-14-2019, 09:46 AM   #2
corvette8n
corvette8n's Avatar
Default Re: LED headlight replacement for 6v. sealed beams
I've seen bulbs, but no sealed beams. The best way to prolong bulb life is to eliminate vibration and be sure there is a good ground. When I owned my '50 Ford I ran a seperate ground wire to the socket, also most LED's are not focused correctly to use as headlights.
Old 01-14-2019, 11:49 AM   #3
flatheadmurre
flatheadmurre's Avatar
Look for 7" H4 conversion kits then buy a H4 led bulb.
The curved glass ones looks real good as a substitute.
Cheap led headlight bulbs has a dodgy beam...sometimes it´s even a hazard for people meeting you in traffic...so pic a good led bulb.
