01-08-2019, 12:56 PM | #1 |
Missing Cap, Inner Universal Joint Housing
Here's a good one for everybody: My car is missing the Inner Universal Joint Housing!! I am wrapping up my clutch install and I was pondering the TWO universal housing gaskets... I've been driving around without this part since before i did my clutch job. It is a bit disconcerting...however it looks like the inner housing's main function is to keep the grease inside the joint and not let too much of it go down the driveshaft. Should I be safe to continue to drive it like this or should I wait until I can source the part?
Oh...anybody have one for sale? Part # A-4513-A it is the equally spaced-type spacer....
"I have not yet begun to defile myself." -Doc Holliday '31 Tudor, '69 F100, '66 Mustang, '11 Ford Flex |
01-08-2019, 02:46 PM | #2 |
Re: Missing Cap, Inner Universal Joint Housing
Check with Bert's Model "A" Center. 303-293-3673 www.modelastore.com
01-08-2019, 02:53 PM | #3 |
That part also keeps the rear axle from moving forward.
Bob |
01-08-2019, 03:39 PM | #4 |
Here is an article I di9d on the assembly if you are interested...if not...oh well!
http://www.plucks329s.org/pdf/studie...y_restorer.pdf Pluck |
01-08-2019, 05:47 PM | #5 |
That article was very informative. Thanks. Now if I could just find that part!
01-08-2019, 06:00 PM | #6 |
They also know which repro parts are good and which not so good. |
