Old 12-19-2018, 06:02 PM   #1
TinCup
TinCup's Avatar
Default Model B Distributor Swap
I have always misunderstood that to use the Model B distributor in that you had to wire your existing ignition cable to the distributor. Since I have finally been schooled correctly If you have made this swap what have you done with your existing setup?
TinCup is offline   Reply With Quote
