Old 01-11-2011, 09:52 PM   #1
Big Shark
Big Shark's Avatar
Default welding a block
Anyone have success welding a hole in the side of a flathead? The hole is the size of a pencil eraser? Thanks Bruce
Big Shark is offline   Reply With Quote
Old 01-11-2011, 10:19 PM   #2
Ronnie
Ronnie's Avatar
Default Re: welding a block
Drill and tap for 1/8" pipe plug if there is room.Why weld if you don't have to. Cast iron can be a real crap shoot unless done by a creditable welding shop get some quotes.Welding would be my last choice just my .02. What caused the hole?
Ronnie
Ronnie is offline   Reply With Quote
Old 01-11-2011, 10:24 PM   #3
1931 flamingo
1931 flamingo's Avatar
J.B. Weld ?? Nothing to lose.
Paul in CT
Old 01-12-2011, 10:57 AM   #4
19Fordy
19Fordy's Avatar
Ronnie hit the nail on the head. When I installed 59AB heads on an 8BA block I used a pipe thread tap and then screwed in a pipe plug with non hardening Permatex so it was just below the deck surface . Then covered it with JB weld. That was 10 years ago and it's still holding. I think you could do the same.
Old 01-12-2011, 12:07 PM   #5
FRANK PKNY
FRANK PKNY's Avatar
How about posting of photo of the problem area. How large exactly and what caused the hole. Never seen a small (bullet hole?) Don't weld if possible. Let's get more infomation first. JMHO Frank pkny
FRANK PKNY is offline   Reply With Quote
Old 01-12-2011, 12:40 PM   #6
Karl Wolf
Karl Wolf's Avatar
My 2 cents...
Wonder why you have that hole- look for cracks around the hole, AND pressure test AND magnaflux the block befor going to other expence... I have a fair amount of respect for brazing on the outside of a block- if you do, try to get the whole block at least warm first... Karl
Karl Wolf is offline   Reply With Quote
Old 01-12-2011, 02:02 PM   #7
52merc
52merc's Avatar
i agree with karl brazing is best but get the block area where you are going to braze warm first this will help
52merc is offline   Reply With Quote
Old 01-12-2011, 09:38 PM   #8
Frank The Plumber
Theres a special welding alloy rod for it but you only get one shot. Put a holler on the HAMB and see if any of those guys know a local that can show you a bit of his work.
Frank The Plumber is offline   Reply With Quote
Old 01-12-2011, 09:57 PM   #9
perrysmith
As I recall my late ol-school father brazed even pressure vessels of cast iron. He could do pretty oxy-acteylene and stick welds, but he definately was not going for
looks when he brazed cast iron. I think also, that warm was an understatement...more like rosebud hot on the part to be welded.
perrysmith is offline   Reply With Quote
Old 01-13-2011, 11:19 AM   #10
burly
burly's Avatar
I recently drug out a 59L block I bought from a gent a few years ago. Upon closer inspection I've found a hairline crack on the back of the bellhousing just below the 59. I suspect it may have mounted it an engine stand at one time. Do I need to expect this to get worse? Any suggestions for repair? Thanks Guys
burly is offline   Reply With Quote
Old 01-13-2011, 06:15 PM   #11
Jack E/NJ
Jack E/NJ's Avatar
Big Shark Bruce: I'd suggest rounding out the hole if need be. Then use either an appropriately-sized metal, plastic or rubber expansion plug.
Burly: Are you sure the hairline crack isn't just a surface casting imperfection? Can you see if it extends to the inside surface?
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 01-13-2011, 06:38 PM   #12
Ol' Ron
Ol' Ron's Avatar
I had a similar problem and just drilled it out for a 1/4" npt plug.
Old 01-13-2011, 07:52 PM   #13
coilover
Always wondered how Ford welded the entire sides onto the 1937 V8 60 block. They were welded with one continuous bead around the entire perimeter and the weld was beautiful.
coilover is offline   Reply With Quote
Old 01-16-2011, 03:31 PM   #14
Big Shark
Big Shark's Avatar
I tried a couple of things in the shop Saturday. I took a steam trap (its cast iron), and drilled a couple of holes in it to practice my welding. I tried spray-metal, certanium rod, and a castiron rod. The spray metal would just ball up. The certanium rod cracked when it cooled, The cast rod looked great. Until I pressure checked it. It leaked were the weld met the cast. I think I will try the brazing method. Ill let you guys know how it turs out. Bruce
Old 01-16-2011, 05:04 PM   #15
Ronnie
Ronnie's Avatar
The crap shoot syndrome now begins. You won't get same results with a block if the cast iron properties are different from your test piece.
Ronnie
Old 01-16-2011, 05:17 PM   #16
FRANK PKNY
FRANK PKNY's Avatar
I braze a lot of cast iron printing press parts. Braze works well but you must heat up a large area. The entire block would be best, I know that is not practical. You can ruin the block very easly. I brazed a tractor block years ago. Getting things very hot is important. Yesterday I brazed a cast iron model T muffler end. It came out great. Engine blocks can be tuff , cracking when cool downing. That's why the entire block should be heated. I don't remember exactly what tempeture you need possibly someone else can jump in.
Old 01-16-2011, 05:42 PM   #17
Kurt in NJ
Kurt in NJ's Avatar
Here is some reading on cast iron welding---
http://www.locknstitch.com/castironwelding.htm
it describes the problem you have and how to do it properly
Old 01-16-2011, 06:55 PM   #18
Marv
Marv's Avatar
I use nickle rod for most cast iron if i am using a stick welder. Marv
Marv is offline   Reply With Quote
Old 01-16-2011, 08:15 PM   #19
southfork
southfork's Avatar
An old mechanic/welder near me used to weld up blocks with massive damage. He once showed me a block where he'd nickel-welded about six pieces of cast together that had been knocked out the side of the block in his pickup. It looked like a puzzle, but the engine didn't leak afterward. after seeing that, I asked him to weld the end of my Model T engine block where a 1 X 2 inch piece of water jacket had broken out due to freezing. That weld is pretty. He'd heat the block with a torch before using the nickel rod, and he'd skip around when doing the arc-welding.
southfork is offline   Reply With Quote
Old 01-16-2011, 10:37 PM   #20
Ken/Alabama
Ken/Alabama's Avatar
I had a block about 10 yrs ago that had a hole about 1/2" diameter on the drivers side just above the oil pan rail . The hole didnt show up until the block went through the cleaner . I layed the block on its side and braced it up so the hole was pointing straight down. I then mixed up a whole tube of J.B. weld and kept poking it into the hole then cut a piece of sheet copper and clamped it up overnight. That engine is in a friends 40 and has never leaked a drop after all these years and several thousand miles.
Ken/Alabama is offline   Reply With Quote
