Old 12-11-2018, 07:13 PM   #1
A V8 Al
Default FN!!STtXx!! Window channels
I replaced the (missing) door window channels and regulators on my 1933 T 1 1/2 truck. The regulators are Vintique and work ok (?); but the window channels I bought from Mac's a while back ( Argentina made) are an impossible fit. The large slot access hole is too small, the slot is too narrow and too thick, and the slot is too short. Are there any better alteratives to these pieces of STXx!,...? Ticked off Al
A V8 Al is offline   Reply With Quote
Old 12-11-2018, 07:52 PM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: FN!!STtXx!! Window channels
First, there are much better repro's of the bottom channel for 1932-33 made by United Pacific.
Second, if you are using Vintique regulators, they are likely 1926-31 coupe/tudor/pickup, of which the end will not work on the 1932 bottom channels. The end would need to be changed to the 1932 style.
Karl Wescott is offline   Reply With Quote
Old 12-11-2018, 08:14 PM   #3
A V8 Al
Thanks for the input Karl. I bought the regulators from CG Parts listed as 1932-34 pickup truck. I need to replace the roller on the lift arm?
