Old 11-30-2018, 06:50 PM   #1
A V8 Al
Default Door window regulator
Having a problem installing door windows in my 1933 ford truck. The stud on the end of the window regulator arm will not fit thru the hole and slot of the window glass channel. Also, the stud on the driver door regulator is spring loaded and moves in and out, the stud on the passenger door regulator is larger and doesn't move. What's wrong. Thanks Al
A V8 Al is offline   Reply With Quote
Old 12-01-2018, 12:50 PM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: Door window regulator
The larger slider that is not spring loaded is likely model A coupe/tudor/pickup. Model A fordor/victoria/cabriolets and 1932-39 v8 used the spring loaded end.
Karl Wescott is offline   Reply With Quote
