Old 11-24-2018, 07:29 AM   #1
wkuehnis
wkuehnis's Avatar
Default Water in my engine oil. Where could it come from ?
Hi,
Today I removed mx timing gear cover.
The inside looks very strange . Its grey and like an emulsion.
So I think, there is water from the radiator in my engine oil.
Quedtion:
Thanks
Willi
wkuehnis is offline   Reply With Quote
Old 11-24-2018, 07:32 AM   #2
29spcoupe
29spcoupe's Avatar
Default Re: Water in my engine oil. Where could it come from ?
Could be from a blown head gasket, crack in water jacket.
29spcoupe is offline   Reply With Quote
Old 11-24-2018, 07:43 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Also can be condensation build up from cold starts and short drives.
Old 11-24-2018, 09:09 AM   #4
wkuehnis
wkuehnis's Avatar
About head gasket: all plugs looks good and looks the same. They would look different with blown head gasket
Old 11-24-2018, 09:12 AM   #5
wkuehnis
wkuehnis's Avatar
I will try to close the water in and oulets and then try to blow air in . Maybe I will see or hear, where it leaks.
Old 11-24-2018, 11:34 AM   #6
katy
katy's Avatar
Ditto
I will try to close the water in and outlets and then try to blow air in . Maybe I will see or hear, where it leaks.
I would suggest that you don't do that as you could possibly damage your radiator.
Do you run straight water? Or anti-freeze mix? If you run anti-freeze mix then I would suspect condensation, as Tom suggested.
Old 11-24-2018, 12:18 PM   #7
johnbuckley
johnbuckley's Avatar
Easy things first before you start worrying .. as Tom says in #3 first of all ,
consider other things .....
I'd change oil, and see if it happens again.
If it does re-occur take head off and change head gasket
see if it happens again, if it does then suspect possible crack etc etc
johnbuckley is offline   Reply With Quote
Old 11-24-2018, 02:21 PM   #8
midgetracer
midgetracer's Avatar
Originally Posted by katy View Post
Ditto
If you close the inlet and outlet, how would it affect the radiator? The radiator would be out of the circuit.
midgetracer is offline   Reply With Quote
Old 11-24-2018, 05:37 PM   #9
100IH
Remove the drain plug in the bottom of the oil pan with a catch pan under it. don't drop the plug, just tip it to the side to let the coolant come out slowly until it stops. Coolant will be at the bottom, oil on top. This is a beginning only. and, yes, do not pressurize the radiator.
100IH is offline   Reply With Quote
Old 11-25-2018, 09:13 AM   #10
wkuehnis
wkuehnis's Avatar
Hi, of course, I dont presurize the radiator. I removed it. The radiator can not bring coolant into the oil.
I presurized it now, but I didn't find out anything.
Condensed water sounds good, but also the other sympthoms made me looking for a leaking in the Jackets or around the valves:
1. Oil level was suddenly higher than expected, higher than maximum.
2. Coolant level in the radiator went down.
So I am still confused,
Willi
Old 11-25-2018, 09:18 AM   #11
wkuehnis
wkuehnis's Avatar
@katy and 100ih: I dont understand: how can my coolant (wit antifreeze) come into the oil?
Thanks for any ideas
Willi
Old 11-25-2018, 09:44 AM   #12
midgetracer
An oil analysis from an oil lab can tell immediately if it is condensation or coolant leak. antifreeze in the oil will destroy babbit bearings in short order. Caterpiller dealers have oil analysis capabilities.
Old 11-25-2018, 10:36 AM   #13
johnbuckley
Smile Re: Water in my engine oil. Where could it come from ?
2. Coolant level in the radiator went down. Willi
The sudden change makes me suspect leaking head gasket rather than condensation. So...change oil and 1) Check that cylinder head bolts are correctly torqued. If still having problems take head off, have a quick look if any obvious cracks, if it looks OK then simply put a new gasket on ( and use some sealant such as blue hylomar if you like and the instructions don't say otherwse). retorque head bolts after 20 miles and 50 miles and 100 miles ( or 30 kms 80 kms 150 kms if you prefer ) If still having problems crack test.
PS you mentioned earlier "... all plugs looks good and looks the same. They would look different with blown head gasket" If the head gasket was severely blown yes there would be other symptoms too, but if the coolant is simply "weeping" through the gasket then there may be no change at all, other than occasional misfire or hesitant starting.
Old 11-25-2018, 11:21 AM   #14
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Hello Willi:
Two places to check is first head gasket as typically number three cylinder will go first.
Second is to remove side cover as Model A engines have weak area in valve chamber around number three cylinder and will crack and leak water into oil.
see picture.
There is a friend of ours in Aarau, Switzerland that can help you.
He is Proficient in Model A engines.
J and M Machine is offline   Reply With Quote
Old 11-25-2018, 11:31 AM   #15
Ernie Vitucci
Ernie Vitucci's Avatar
Good Morning all...Years ago, I was taught that flat head engines should be re-torqued once a year, as they have a tendency to work loose and bolts can stretch and washers can collapse. All the suppliers sell a C shaped wrench to add to your torque wrench to make the job easy. They also have a chart that shows the tightening sequence if you don't have it...only takes half an hour and it is good insurance. Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 11-25-2018, 12:46 PM   #16
DHZIEMAN
Hi,
Quedtion:
Thanks
Willi
Is the engine oil in the pan milky? If not, I would venture condensation!
DHZIEMAN is offline   Reply With Quote
Old 11-25-2018, 02:44 PM   #17
ursus
Originally Posted by J and M Machine View Post
Hello Willi:
see picture.
es.
I have just the valve chamber cracks depicted by J & M Machine. A machinist said that these would be problematic for pinning as he would be drilling into the cylinder. Since there is no water pressure, could the problem possibly be fixed with the newer block sealer products such the Fiber-Lock stuff made by K & L?
ursus is offline   Reply With Quote
Old 11-25-2018, 03:06 PM   #18
johnbuckley
Originally Posted by ursus View Post
......could the problem possibly be fixed with the newer block sealer products such the Fiber-Lock stuff made by K & L?
Certainly worth a try! ( Reminds me of a 1950s book "Overlanding with Annabelle"- they had a cracked block in a Chevrolet truck and put in "Chemiweld" (whatever that was!) and successfully drove round Australia without any problems.
Old 11-25-2018, 03:49 PM   #19
Synchro909
Synchro909's Avatar
Chemiweld uses sodium silicate to seal. It is a local product and is still available. It works wonders. I don't have a bottle of it at the moment but it is added to the cooling system with the motor warm and running after a good flush.
I have absolutely no reason to doubt that after using it, they were able to drive around the country and I bet the engine still running well for a long time after. It has been about here for decades and stories of miraculous "workshop in a can" feats are numerous.Here is a link to the manufacturers descrption:
http://www.goss.com.au/assets/Upload...nformation.pdf
I'm sure other sodium silicate products will work just as well. One of them might help out our original poster.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 11-25-2018, 07:17 PM   #20
abachman3
abachman3's Avatar
Run a compression test to see if the head gasket is compromised.
abachman3 is offline   Reply With Quote
