#1 |
I am thinking about getting a wolf whistle for my roadster, but I don't know what I should get. I know Snyder's makes a cheap reproduction but I also know there are a fair amount of originals out there. Is anybody running a repro?
#2 |
Find an original
#3 |
If you get an original make sure it has the whistle part in it. Looks like a disk with holes in it at the bottom of the bell. At least 2 years ago you could get a replacement.
#4 |
what is an original? I have one about 50 years old from the 60's. Is it an original ?
#5 |
I know they were being produced during the Model A era, maybe even earlier. They have been a popular accessory ever since, so one from the 60s is not technically what a model a would have had back in the day, but it probably would work.
#6 |
#7 |
Check Speedway, I am pretty sure that is where I got mine.
#8 |
In the 60's the cheap red wolf whistle was $2.98 from JC Whitney, and the deluxe one with the bellcrank to push the valve was $4.98. I bought the deluxe one and it worked well, but I had to spray lube on the whistle part about once a month, or it might not spin.
Today's repro of the deluxe whistle is about $50, and most likely made in China. |
#9 |
It is funny how sometimes something will stick in your head for a lifetime whether it is factual or not. 54 years ago and I was 18 years old I was going to order a wolf whistle from J.C.Whitney to put on our newly rebuilt Model A engine and my dad nixed it. He always had this theory about exhaust and vacuum that he learned from an old mechanic,a Model T and Model A era mechanic.He believed that anything other than factory engineered exhaust back pressure would lead to premature valve damage. In theory it seemed to make sense with his comparison to a blacksmiths bellow,more air over metal more heat,red hot to white hot and exhaust back pressure,mufflers are much more than just noise suppression.Rather right or wrong I don't know but something I always think of when I see or hear a wolf whistle.I opted for the 6 volt Jubilee Bull Horn which I still have but it is on my '37 coupe.
"Never complain,never explain"... Henry Ford II |
#10 | |
#11 |
…..well, I can only tell you that I have 10's of thousands of miles on my Roadster that has always had a wolf whistle on it and true, I rebuilt my engine last year but, I doubt that engaging the whistle had anything to do shortening the life of said engine.
#12 |
The wolf whistle works on the intake side not the exhaust side of the manifold. Shouldn't affect the exhaust. It does momentarily affect the air intake, as you are introducing more air through the whistle than without one. At idle you can hear the change in the engine speed.
#13 |
Speedway does still have the motor / disc for the Wolf Whistle , even though I couldnt find it on their web site . here is e-mail from them about it .
You inquired about the motor for the older Wolf Whistles and they are still available under part number 91063250-3 at $9.99 each. Feel free to give us a call at 1-800-979-0122 or check out our website at www.speedwaymotors.com. Let me know if we can be of further assistance and thanks again for shopping Speedway Motors John Wulbern | Street Rod Tech Speedway Motors 340 Victory Lane, Lincoln, Ne. 68528 [email protected] |
#14 | |
#15 |
I just put my fingers between my lips and let 'er rip !
Doesn't affect the engine performance one bit ! It COULD affect my driving if my wife were along....
Always one bad decision away from a good time. |
