Old 10-22-2018, 10:28 PM   #1
JoeBauer
Default Firing order
I guess we all know the firing order on a T is 1-2-4-3. But, what is the proper way for the wires to be connected to the plugs?
In the picture the engine has a new wiring harness between the coil box and the timer. The color coded wires are hooked correctly to the timer. Notice the plug wires come from the box with the wires from 3 and 4 crossed. I have seen other engines done this way, and I believe it to be correct.
But I have also seen engines with the plug wires going to 3 and 4 not being crossed. I find that visually pleasing, but doesn't it mean that a couple of timer wires are not to their color coded terminal on the timer?
JoeBauer is offline   Reply With Quote
Old 10-22-2018, 11:10 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Firing order
Your photo doesn't look right to me but my coil box is on the firewall. my wires between the coils and timer are placed so the wires from the coils to the plugs are 1234. The firing order is still 1243.
Old 10-23-2018, 04:31 AM   #3
JoeBauer
My mistake, I have the green and blue wires swapped on the timer. The green is definitely longer than the blue in the harness, so I am still a bit confused.
The '26 and '27's had the coil box on the block. Where the coil box is mounted is not a factor.
https://www.bing.com/images/search?v...ing&ajaxhist=0
Old 10-23-2018, 04:33 AM   #4
JoeBauer
Picture as I installed...
Old 10-23-2018, 06:05 AM   #5
29spcoupe
29spcoupe's Avatar
I cross the timer wires and leave the plug wires un-crossed.
29spcoupe is offline   Reply With Quote
Old 10-23-2018, 07:38 AM   #6
JoeBauer
That is the correct way to do it.
In my picture, the blue wire should go up over the timer to the 10 o'clock terminal, the green wire should go to the terminal where the blue wire is in the picture - 4:00 o'clock. That puts the blue wire behind the spark control rod when it is installed.
I should have done more research before starting this thread, but now I know!
https://www.bing.com/images/search?v...114&ajaxhist=0
Old 10-23-2018, 03:26 PM   #7
tmodelman
The engine mount coil box is different from the cowl box wires to the plugs. The cowl box Left to Right is 1-2-3-4 to the plugs.
The engine mount '26-'27 is Left to Right 4-3-2-1 to the plugs, i.e. the terminal next to the radiator is #1 plug.
For the '26-'27 commentator loom, the loom goes over the front of the engine to the timer. At the timer, the Blue is to top right of the timer rod hole, Black is top left, Red is lower left, and Green is lower right.
tmodelman is offline   Reply With Quote
Old 10-23-2018, 06:13 PM   #8
J Franklin
J Franklin's Avatar
I tried once to crank start a T that the timer wires were crossed by the previous owner as in your photo but the plug wires were not. I should have inspected first!
Old 10-23-2018, 07:21 PM   #9
JoeBauer
tmodelman's diagrams are the way it should be done. I have seen T's done both ways, and they run equally as well, but I want mine like Henry made it, and now it is.
Old 10-23-2018, 09:53 PM   #10
J Franklin
J Franklin's Avatar
Looks good!
Old 10-24-2018, 05:15 AM   #11
39portlander
39portlander's Avatar
Joe some good photos that help, this is a great thread as I will be finishing my valves and getting the head back on this week.
Planning to start wiring and get the front timer with related parts back together this month.
39portlander is offline   Reply With Quote
Old 10-24-2018, 06:33 AM   #12
JoeBauer
It would be nice if you could take some pictures and describe the process. Pictures like the bottom center that tmodelman posted really help me. If you post pictures of your build it might help others.
I am fairly new to T's, most of my info comes from the internet. T people are good at sharing!
For example, if you post pictures of the valve installation process and tools used and what type of valves, and clearances necessary etc. with a description it would help someone (like me) who has never been through the process. It does take some time to photograph as you go along, but this forum is very user friendly when posting pictures.
What year are you building?
