Old 10-05-2018, 10:28 PM   #1
California Charlie
California Charlie's Avatar
Default Transmission Work Stand
I've been helped several times from this site that I thought I would pass this information on to those working on rebuilding their transmissions. I ran across this a while ago, and from memory I constructed this transmission stand with perhaps a few improvements.
Some of you may be familiar with this transmission stand made simply from 3/4" pipe fittings. It worked great for me and made the rebuilding assembly of the transmission very easy.
California Charlie is offline   Reply With Quote
Old 10-05-2018, 11:02 PM   #2
Glen in Hillman MI
Default Re: Transmission Work Stand
Looks handy - good work.
Glen
Glen in Hillman MI is offline   Reply With Quote
Old 10-06-2018, 11:18 AM   #3
Russ/40
Russ/40's Avatar
Handy, but all that pipe can be expensive.
Russ/40 is offline   Reply With Quote
Old 10-06-2018, 02:14 PM   #4
CarlG
CarlG's Avatar
But for guys like me that don't weld, --
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-06-2018, 04:58 PM   #5
d.
to save pipe expenses...I have seen this same idea done with just the 3/4 downpipe coming off the trans drain hole with a T fitting at the bottom and clamped in a vise.
d. is offline   Reply With Quote
Old 10-06-2018, 07:12 PM   #6
fredski53
fredski53's Avatar
Looks good...but, isn't that a lot of stress on the area where the drain plug goes?
fredski53 is offline   Reply With Quote
Old 10-06-2018, 09:08 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
I use a short piece of pipe and fit the lower end into a 2 x 12 about a foot long.
Cheap and easy tranny holder.
Old 10-06-2018, 10:13 PM   #8
Rich in Tucson
Rich in Tucson's Avatar
I do the same, with a hole in the 2 X 12 sose I can direct solvent used to preliminarily clean the gearbox (before disassembly) into a metal pan below for waste removal.
Rich in Tucson is offline   Reply With Quote
