Old 09-09-2018, 04:23 PM   #1
V12Bill
V12Bill's Avatar
Default F1 Cowl Vent
I took my cowl vent apart to paint the lid and trough and to replace the gasket on my 1950 F1. The lid does not close tight nor will it lock down. I see a spring loaded nut and bolt on the left side and adjusting it up and down increases the tension on the lid, but no adjustment is satisfactory. My shop manual skips over this adjustment. Has any one had success in making this adjustment?
V12Bill is offline   Reply With Quote
Old 09-10-2018, 08:33 AM   #2
V12Bill
V12Bill's Avatar
Default Re: F1 Cowl Vent
ttt
Old 09-10-2018, 09:03 AM   #3
38bill
38bill's Avatar
When I did mine I found that the new gaskets available were too hard of a rubber and the vent would not close no matter how I adjusted it. I ended up buying some of soft foam "D" shaped weather stripping and made my own gasket. I just cut it to length and super glued the ends together.
38bill is offline   Reply With Quote
Old 09-10-2018, 10:30 AM   #4
Ross F-1
Ross F-1's Avatar
That looks really nice, Bill! Do you know the p/n for that rubber? Does your handle lock in the down position? Not clear that they are supposed to, there's a little track for the spring-loaded bolt that would appear to lock it, but I can't get mine to go in there.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 09-10-2018, 12:07 PM   #5
V12Bill
V12Bill's Avatar
Apparently others have a problem with this adjustment also.
Old 09-10-2018, 12:51 PM   #6
cmbrucew
cmbrucew's Avatar
Here are some instructions provided by Bob Drake.
Bruce
File Type: pdf 01A-426-HK-CI Cowl Vent Hardware Kit.pdf (1.32 MB, 37 views)
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 09-10-2018, 02:35 PM   #7
JSeery
JSeery's Avatar
There have been previous post/threads on having to cut the vendor gaskets horizontally as they come to thick. Being too hard is also an issue.
Old 09-10-2018, 02:51 PM   #8
V12Bill
V12Bill's Avatar
Bob Drake instructions would be excellant if I had a 1940 Ford. I have a 1950 pickup.
Old 09-10-2018, 02:54 PM   #9
38bill
38bill's Avatar
I don't remember were I got it from but there are a couple of weatherstrip manufactures that have the same thing. I seem to remember that JC Whitney actually had it at the best price but that would have been 18 years ago. The lever feels like it goes "over center" and the vent locks down tight. Pretty sure that I held the vent down and then tightened all the linkage.
Old 09-10-2018, 02:55 PM   #10
JSeery
JSeery's Avatar
Not sure instructions are going to solve your problem, might be worth reading some of the past post.
Old 09-10-2018, 04:57 PM   #11
Ken Crans
Ken Crans's Avatar
I had no problems with my new gasket... You have to get under dash to adjust, their is a little slot for lock position, loosen up spring loaded nut to find position which should be closed. Then when opening, you'll have to move lever over to open.
Ken Crans is offline   Reply With Quote
Old 09-10-2018, 05:08 PM   #12
12cliff23
interesting thread, I got my gasket from LMC same problem to thick, never gave it much time now maybe I will, thanks
12cliff23 is offline   Reply With Quote
Old 09-10-2018, 07:21 PM   #13
Big Red 51
Big Red 51's Avatar
V12
I got my vent gasket from D Carpenter about 6 years ago for my '51 F1 and it fit perfectly, no adjustment needed. Don
Big Red 51 is offline   Reply With Quote
