Old 08-20-2018, 12:58 PM   #1
Init1
Init1's Avatar
Default 15" Ford hubcap dilemma
I'm searching for a Ford hubcap that will cover
40 Ford front and rear hubs and snap on Ford 15" pickup wheels with 4 mounting nubs on the outside.
There must be some options?
Init1 is offline   Reply With Quote
Old 08-20-2018, 01:52 PM   #2
Bursonaw
Bursonaw's Avatar
Default Re: 15" Ford hubcap dilemma
If I’m reading your question right any 1940 through 1948 Ford hubcap will work on Ford Truck 15” rims.
Hope this helps.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 08-20-2018, 02:34 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Hope this helps.
.........ONLY on TRUCK wheels up to '66, I believe, are the 'nubie's mounted on the INSIDE! '40-'48 caps will NOT fit outside nubies. '67 or so is When the wheels went to the big OUTSIDE nubies. There should be a "cheap" factory cap to fit these later wheels, but I'm not sure they would necessarily clear the bearing and axle shouts on the early axles. You need to find four '53-'56 15" pick-up wheels with the nubies on the inside, to be able to run the cool, early caps. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-20-2018, 02:35 PM   #4
Lanny
Lanny's Avatar
[QUOTE=Bursonaw;1665575]If I’m reading your question right any 1940 through 1948 Ford hubcap will work on Ford Truck 15” rims.
Hope this helps.
As the OP says in his post, he has the OUTER Nubs, so he has 1967
and newer Ford pickup wheels which take a 10 1/4" hubcap.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 08-21-2018, 12:33 AM   #5
deuce lover
deuce lover's Avatar
50 Merc hupcaps might work.After finding this listing maybe not.
https://www.ebay.com/itm/1950-OEM-Me...0AAOSwqYBWmohk
deuce lover is offline   Reply With Quote
Old 08-21-2018, 09:24 AM   #6
TJ
TJ's Avatar
The '49 and later Ford passenger car hub caps may fit or some aftermarket baby moons that use the outside nubs may fit.
Old 08-21-2018, 01:13 PM   #7
blucar
blucar's Avatar
The easy way to solve the hub-cap wheel problem is to use '57-66 F100 wheels. The hub-cap knobs will be on the inside of the wheel hub, just like the stock '40 wheels.
Ford went to the external knobs in '67 on the F100's, which is similar to the '49-50 Merc wheels and the '49 later Ford cars.
Be careful buying the 15" wheels, the '47-48 15" wheels look the same, however they are only 4.5 wide.
Bill.... 36 5 win cpe
Old 08-21-2018, 01:24 PM   #8
funrunr
funrunr's Avatar
67-77 Bronco and pick up, along with Ford Galaxie used these hub caps and I know for certain they will clear 1940 axle/hubs. I've seen them on a 40 convertible that is local.
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
