Old 08-16-2018, 08:35 PM   #1
AnthonyG
AnthonyG's Avatar
Talking New Ride, ‘40 pickup
Came across a great ‘40 pickup. Really nice condition. Can’t believe what a great price. Car was stored in heated garage for 23 yrs. owner decided to let it move on. Odd but interesting engine trans, 440 ci Mopar w Torque Flite. Disc fronts 9” Currie rear. Correct chassis but boxed, sheet metal & chrome stock. Very happy camper!
Nomad
AnthonyG is offline   Reply With Quote
Old 08-16-2018, 08:51 PM   #2
JSeery
JSeery's Avatar
Default Re: New Ride, ‘40 pickup
Very nice body!
Old 08-16-2018, 08:51 PM   #3
fottyjs
What a beauty!!!!
fottyjs is offline   Reply With Quote
Old 08-16-2018, 09:07 PM   #4
AnthonyG
AnthonyG's Avatar
Will work on first start this Sat. Haven’t cranked with starter yet. Checked & crank wasn’t ftozen moved freely. Oil & tranny fluid clean & clear but 23 yrs old. Will drain all fluids shoot cylinders up with a Coil thru spark plug holes, drain flush all as per car that hasn’t started for yr’s procedure. Anxious to get it rolling!
Nomad
Old 08-17-2018, 07:08 AM   #5
corvette8n
corvette8n's Avatar
Nice looking truck, when your tired of the 440, you can put a screaming flatty back in it.
Old 08-17-2018, 07:57 AM   #6
V8COOPMAN
V8COOPMAN's Avatar
Maybe you can donate those wheels and tires to some GANGSTA' in a 'hood near you. Or...…...maybe NOT so near. Body seems straight! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-17-2018, 08:25 AM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
Nice looking pu Tony!
John
Old 08-17-2018, 08:26 AM   #8
JSeery
JSeery's Avatar
Is the interior anywhere near original or completely changed out?
Old 08-17-2018, 02:03 PM   #9
AnthonyG
AnthonyG's Avatar
DD�� wheels gotta go 4 sure ����. J, interior not stock. Not too bad though. Grey Tufted & pleted bench & door panels. All steel in great shape, thx John & all 4 comments
Nomad
Old 08-17-2018, 09:57 PM   #10
TomT/Williamsburg
TomT/Williamsburg's Avatar
Nice solid truck from the pics. Once you have it straightened out, should be a great ride. Rear looks wide but with some negative offset rims, it will be fine?
TomT/Williamsburg is offline   Reply With Quote
Old 08-17-2018, 10:15 PM   #11
AnthonyG
AnthonyG's Avatar
Thx Tom & agreed on wheels. Front wheels same issue. Need less offset on all.
Nomad
Old 08-17-2018, 11:22 PM   #12
harleyjohn45
harleyjohn45's Avatar
Very nice, you will love it.
harleyjohn45 is offline   Reply With Quote
Old 08-20-2018, 09:34 PM   #13
G32
AnthonyG;
Nice looking 1941! The hood trim is 1941 --the tailgate is 1941. 1940 tailgate was
stamped "Ford V8" -- 1941s had v8, 4 cylinder and the first 6 cylinder engines
available- thus only "Ford" - no V8 on tailgate.
Check the serial Number list to confirm Ford's model year.
No offence --just id info.
Keep our old Fords on the road---good pictures! Thanks man!
Gene Tulsa
G32 is offline   Reply With Quote
Old 08-22-2018, 04:20 AM   #14
dumb person
dumb person's Avatar
Nice body but i'd be very tempted to start swapping it back to a more stock look.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 08-22-2018, 08:00 AM   #15
TJ
TJ's Avatar
Interesting that the spare is on the left side. I didn't think that happened until 1942. If the bed is 48' wide you may have a '42 bed.
Old 08-22-2018, 03:24 PM   #16
AnthonyG
AnthonyG's Avatar
Thx all, knew it wasn’t stock. Loved the sheet metal & price was right got some more stuff stock guys would worry about but I’m not. Titled as a ‘40. Know the hood is ‘41, Thx 4 tip on tail gate evidently also ‘41. I’ll check the bed as suggested but even if ‘42 or ‘42 I’m fine with that too. Most will probably freakout but also has a vent type skyline. Installed well & I like it
Nomad
Old 08-23-2018, 08:29 AM   #17
Cecil/WV
Cecil/WV's Avatar
Nice project to put a flathead in!
Cecil/WV is offline   Reply With Quote
Old 08-23-2018, 12:43 PM   #18
estout81
I think it is WAY beyond a flathead.
estout81 is offline   Reply With Quote
Old 08-23-2018, 04:41 PM   #19
AnthonyG
AnthonyG's Avatar
Estout81 ur right. I do love flatty’s & have a ‘35 w a ‘49 perf’ed up 8BA this one is destined to stay in the more modified than not class. I will keep all the sheet metal & paint as is. Will put Stock seat upholstery. For now will work w the Mopar 440ci & Torque Flite as it’s there & tightly installed. Once running the engine & tranny R valuable as it’s an 1969 HP series engine. I will sell engine & tranny before next tuneup as it’s that hard to work on! Will go with 302ci / C4 instead.
Nomad
Old 08-23-2018, 04:47 PM   #20
JSeery
JSeery's Avatar
Sounds like a plan.
