08-15-2018, 08:57 AM | #1 |
Blew The Rear End In My '40 coupe
Broke two teeth off the ring gear.
Now I'm having a hard time finding parts for it. (ring & pinion) No new ones seem to be around. Any ideas where to find some new or used gears or a whole rear end? 3.78 Thanks in advance! |
08-15-2018, 09:18 AM | #2 |
Re: Blew The Rear End In My '40 coupe
There's one for sale on HAMB.
https://www.jalopyjournal.com/forum/...r-end.1107760/ More here: https://www.jalopyjournal.com/forum/...&o=relevance&c[node]=47 Here's one on Fordbarn. Will it fit? Do another Fordbarn search as there may be more. https://www.fordbarn.com/forum/showt...+ford+rear+end |
08-15-2018, 09:27 AM | #3 |
Put a wanted ad here and on the EFV-8 club website classifieds. There are plenty of good used parts available for these early Ford banjo rears, but new "quality" bearings are becoming difficult to find.
08-15-2018, 09:30 AM | #4 |
Speedway motors has one, part number 919107E, 1935-48 Ford
08-15-2018, 09:41 AM | #5 |
Is this the gear set you are looking for?
08-15-2018, 10:12 AM | #6 |
41 woodie https://41fordwoodie.weebly.com/ |
08-15-2018, 10:17 AM | #7 |
As always, try Southside Obsolete ("barnfind08" on here); he has a lot of NOS stuff.
08-15-2018, 10:22 AM | #8 |
Speedway and a few other early Ford parts dealers usually have the best price on these repro gear sets. They are all coming from the same original sourse, so may as well go for the lowest price. I believe Speedway is offering free shipping as well. Several friends are using these gearsets in their early Ford V-8's with no problems reported.
https://www.speedwaymotors.com/1935-...ar-,29715.html
08-15-2018, 10:32 AM | #9 |
A good time to consider, up grading to a more modern drive train. Pretty simple to convert your trans to open drive and install a modern rear end. Might be cheaper in the long run.
08-15-2018, 01:02 PM | #10 |
Bob
Check your PM Fourdy |
08-15-2018, 01:39 PM | #11 | |
Charlie Stephens |
08-15-2018, 02:10 PM | #12 |
Bob, have you tried Hagan's up your way? Can't hurt to check and they are close to you....I think!!
Good luck....Dick. |
08-15-2018, 02:24 PM | #13 |
Wish you were closer I got a complete reared out of my 39 that in excellent condition. $250. Double I am in Pa. It 3:78
08-15-2018, 04:07 PM | #14 |
I have a 3:78 used ring and pinion, pinion mounted in banjo.
You can have it - I'm in the Vancouver BC area- email me [email protected] |
08-15-2018, 10:30 PM | #15 |
If you can find a replacement for a reasonable price, by all means go for it. However, unless your restoring an original car, with original parts. Then upgrading to a better, more modern component. Will probably increase the value of your vehicle. This falls under the category of the daily driver.
08-15-2018, 10:35 PM | #16 |
I'd look at a 3.54 ratio depending on terrain, ect.... They are available. Joblot did sell them, nice units to put into stock. Last edited by Tinker; 08-15-2018 at 10:41 PM. |
08-15-2018, 10:36 PM | #17 |
Real 9" fords are getting rare. But they still make them aftermarket. No brainer, great units.
Something about a banjo rearend though. I encourage people to sell their banjos. cheaper the better. Last edited by Tinker; 08-15-2018 at 10:42 PM. |
08-15-2018, 10:56 PM | #18 |
08-16-2018, 07:23 AM | #19 |
08-16-2018, 07:29 AM | #20 | |
