#1 |
My AV8 with '51 Merc in it. Been sitting for a couple weeks so I went to start and run it for a while. After the 2nd try to get it started, I let go of the key and it kept turning the engine over. Turned the switch off and still turning (not running). Had to pull a battery cable. Touched the cable to bat and still did the same. My first thought is the starter relay/solenoid is stuck. Pulled it and checked with a test light across the cable terminals and nothing. Has a universal ignition switch. This car has been run very little since built and everything in the electrical system was new. What else to check?
#2 |
I'd suspect the solenoid regardless. It might be more prone to stick with the heavy amperage of the starter. If it does it again, try whacking the starter with a soft faced hammer. if it unsticks at least you've isolated the cause.
Assuming it was all a-ok before the layup you ought to be able to rule out any wiring issues. Mart. |
#3 |
If you remove the small wire to selinodse, then short to batt and see if it stops .
If it stops work back to wire to ign switch check for shorted wire. |
#4 |
The only way the starter is receiving power is if the starter solenoid is energized, either by being stuck or being externally activated. Being wired to a key switch I assume it is a solenoid that requires power and is wired for 12v. If so, then either the solenoid is sticking or there is power feeding the solenoid even with the switch off.
#5 |
