Old 07-30-2018, 11:33 AM   #1
Teltruck
Teltruck's Avatar
Default Checking Transmission Fluidmin 1949 Ford
How to check the Transmission Fluid level in a 1949 Ford 8BA Engine with standard Transmission. Also, if fluid is needed where do you put it in and what type fluid would I need. Thanks very much.
Bob
Teltruck is offline   Reply With Quote
Old 07-30-2018, 11:41 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: Checking Transmission Fluidmin 1949 Ford
You have a plug on the side of the transmission...you fill up to the level where it will come out the plug.
For gearlube there are many opinions...just make sure it´s safe for the brass syncros.
I use normal 80w90 API GL3 nothing fancy.
Old 07-30-2018, 11:55 AM   #3
JSeery
JSeery's Avatar
GL-4 will be ok. Viscosity depends on how you like the way it shifts.
Old 07-30-2018, 12:44 PM   #4
Teltruck
Teltruck's Avatar
Thanks to all who responded! FordBarners are Very helpful!!! Thanks very much!
Bob
Old 07-30-2018, 12:51 PM   #5
Big Red 51
Big Red 51's Avatar
Bob, One thing(of many) I didn't know when I first had an Overdrive with my standard transmission was add oil to the transmission only but drain both when changing fluid. Service manual does say that somewhere. Don
Big Red 51 is offline   Reply With Quote
