Old 07-28-2018, 10:39 AM   #1
Don
Don's Avatar
Default Bad intake or carb
Friend Bruce J called for help,41 pu 2 middle cyl on rt side truck and 5 & 8 on left are not doing anything,comp is good! Removed carb and it is squirting on both barrels, alsohave fire at all plugs,shorting out those 4 cyl has no effect on idle but nice spark is there,!!! I think the manifold is bad or a burn thru ...I rebuilt carb awhile back and checkout on a engine stand!,ran perfect.....any ideas?......?..He had a misfire before ,that’s why carb was redone, said he had no gas smell in oil!!!
DON P
Don is offline   Reply With Quote
Old 07-28-2018, 11:13 AM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Bad intake or carb
You may have some dirt in a jet. I had that happen when I was in Gettysburg a few years ago at an Eastern National meet. I had someone sit in the car and floor the accelerator and then I put the palm of my hand over the air horn on the carburetor. It sucked the dirt through and fixed the problem.
Seth Swoboda is offline   Reply With Quote
Old 07-28-2018, 11:16 AM   #3
tubman
tubman's Avatar
There was a thread on here a couple of years ago just about like this. It turned out to be that there was a hole burned through in the manifold from the intake passage to the exhaust heat passage. So it does happen.
Old 07-28-2018, 11:16 AM   #4
Mart
Mart's Avatar
Almost definitely - some sediment has found it's way into one of the main jets. I had it happen to me on my 33 coupe not longer after first getting it back running on the road.
Each side of the carb feeds the middle two cylinders on one side and the end two on the other.
Mart.
Old 07-28-2018, 11:27 AM   #5
alanwoodieman
with it running and there was a hole thru the manifold there would be a terribly strong unburned gas odor coming out of the tail pipe
alanwoodieman is offline   Reply With Quote
Old 07-28-2018, 12:23 PM   #6
petehoovie
petehoovie's Avatar
What Seth and Mart said above - Posts #2 & #4.....Had the same thing happen with my '37.....
Old 07-28-2018, 05:35 PM   #7
rick r
rick r's Avatar
Tub man is correct. Buddy had the same problem. Pull the manifold and have a look before tearing into the carb.
rick r is offline   Reply With Quote
Old 07-29-2018, 07:15 AM   #8
Bruce in southern OH
Bruce in southern OH's Avatar
Thanks for all the replies, several people were asked yesterday evening at car cruise in the question Don asked at beginning, most said dirt in main jet. Will advise, Don has carb and will investigate this week. ( This is a cast iron intake )
Bruce in southern OH is offline   Reply With Quote
Old 07-29-2018, 08:47 AM   #9
RKS.PA
RKS.PA's Avatar
Bruce, if it turns out to be the manifold, I have a spare that I think will fit your engine. Let me know.
Regards....Dick.
RKS.PA is offline   Reply With Quote
Old 07-29-2018, 11:23 AM   #10
scicala
scicala's Avatar
To avoid a hickey on your palm, you can also use the choke plate to do this. LOL.
Sal
Old 07-29-2018, 12:40 PM   #11
Sal, was thinking same thing, not good to have a blood clot!!
Hey Dick, I have been off the barn for a year or so, working on the Mustang and Model A cars, sold the 32 pickup to a local guy in Charleston, WV. Appreciate the offer on the intake, just don't see how it would completely shut down all four cylinders. Time will tell. Thank you to every one answering Don.
Old 07-29-2018, 12:43 PM   #12
Sal, do you have a 9194 carb laying around for a 41 pickup truck engine???
Old 07-29-2018, 07:54 PM   #13
Don
Don's Avatar
Have removed jets from carb,no dirt and clean as can be ,pulled emulsion tubes. Looked like new,one jet might have been a 1/4 turn loose,just have to give it a try think the intake should be looked at before putting carb back on
DON P
Old 07-29-2018, 08:38 PM   #14
scicala
scicala's Avatar
Bruce,
The only complete carb I have is an EAB 94, which is for a later year V8.
Charlie ny (Ford Barn member) may have what your looking for. I can also rebuild one for you when you find one.
Sal
Old 07-30-2018, 07:03 PM   #15
Don
Don's Avatar
Bruce picked up carb this morning,and installed ,,,test drove,and reported problem solved,
Apparently when I removed jets and emulsion tube must have done something to correct problem,Bruce is happy and I’m relieved,,,,,,never to old to learn!!!!!
DON P
Old 07-30-2018, 07:58 PM   #16
Thanks Don ( again ), does anyone have a flow diagram or information on the carbs so I can look flow and operation???
Old 07-31-2018, 10:19 AM   #17
Seth Swoboda
Sounds like you had a plugged jet some where. It doesn't take much of a piece of dirt to throw things askew.
Old 07-31-2018, 10:25 AM   #18
Seth Swoboda
I'm not aware of such a diagram. If you take on of these carburetors apart and fill the bowl with mineral spirits, operate the accelerator pump and you can see the basic flow or what is happening inside. There is the idle circuit and then the power circuit for lack of better words. They are very simple carburetors.
Old 08-01-2018, 07:16 AM   #19
Frank Miller
Frank Miller's Avatar
Just draining gas out of carb could have taken the piece of dirt with it. How clean is the rest of the system and is there a fuel filter?
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 08-01-2018, 07:52 AM   #20
New tank several years ago, straight into a Holley Fuel filter, to a Carter electric pump to carb. Clean filter, this carburetor was one we just installed on truck. New gaskets, cleaned, polished, you name it. Assembled like in a "clean room with electronics ". With this said it was a lesson learned, had everyone guessing. Appreciate all the help, as always, Bruce
