07-26-2018, 12:21 PM | #1 |
Shock link nuts
Anyone have a view on this? I've put new 1937 front shock links on the Pilot V8 Woodie and the taper is fine but the thread is very short and there are no split pin holes. So, the threads are too short for nylock nuts or normal nuts with split washers or to drill for split pins. Half nuts with split washers would work, or thread locking compound. What do you do?
07-26-2018, 12:34 PM | #2 |
Re: Shock link nuts
Is there enough room for a PAL nut, after the first are installed?
Or, get thinner nuts? My ACE hardware store calls them jam nuts Jim |
07-26-2018, 12:34 PM | #3 |
Re: Shock link nuts
Double post
07-26-2018, 12:44 PM | #4 |
Re: Shock link nuts
Back-Order Bob is out of stock, but this is what you need. They are thin self locking nuts which are stock design for Ford shock links.
https://www.bobdrake.com/FordItem.aspx?Item=351022 |
07-26-2018, 02:59 PM | #5 | |
Re: Shock link nuts
Check with Roy Nacewicz, the nut man.
07-26-2018, 03:13 PM | #6 |
Re: Shock link nuts
By the way I would love to see a photo of your Pilot woodie. I have seen both Pilot cars (even driven one) and pick-ups but never seen the woodie in the flesh. GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
07-26-2018, 07:10 PM | #7 | |
Re: Shock link nuts
Roy Nacewicz sells them.
07-27-2018, 01:50 AM | #8 |
Re: Shock link nuts
Thanks for the replies; all very helpful. As ever, obscure parts can be hard to get over here in the UK and expensive to ship. Now I know what I need it'll get me on the right track!
07-27-2018, 01:53 AM | #9 |
Re: Shock link nuts
Yes, of course. I'll start a thread if there's any interest. I've got some pictures of the car in the mid 1970s before it was dismantled which are quite fun.
07-27-2018, 02:06 PM | #10 | |
Re: Shock link nuts
GB
07-30-2018, 07:37 AM | #11 |
Re: Shock link nuts
I found thin nyloc nuts at the local hardware store. I'm sure you can find them online. They're about half the thickness of a regular nut, so there's full thread engagement through the nylon. I'd like a little more to be honest, but I'm happy with full engagement in this particular case.
Mike |
07-30-2018, 12:51 PM | #12 | |
Re: Shock link nuts
07-30-2018, 01:16 PM | #13 |
Re: Shock link nuts
Doc, I'd try these. They're all metal, so even though thin, the locking part is still a viable part of the nut. Nylocs can end up with next to no thread if thin and sporting a heavy chamfer on the non locking end.
https://www.ebay.co.uk/itm/1-4-5-16-...HCqRYt4mNAwoVQ If too thick, they could be skimmed down on a lathe. £2.20 for 10. enough to do all 4 corners. Mart. |
