06-29-2018, 04:37 PM | #1 |
34 pinion spline question
I'm putting a Mitchell overdrive in my 34 coupe. It has a 4.11 rear end. When the overdrive arrived it came with a 6-10 spline coupler. My pinion is a six spline so I needed the 6-6 spline coupler. Is six spline correct for a 34\v-8? Or has someone changed it? Don't know what years used six and which ones used ten. I have searched several sites and have mixed results. Thanks, Steve
06-29-2018, 05:11 PM | #2 |
Re: 34 pinion spline question
It would have been 10 spline originally
Question ,do you have to cut the floor plan to fit the mitchel in? Lawrie |
06-29-2018, 05:42 PM | #3 |
Hopefully not! According to their website it requires no body modifications. I'll know when I get the correct coupler. I didn't think the later 6 spline pinion would fit the 33/34 housing with the small pinion bearings? Is it possible to swap them? Steve
06-29-2018, 05:57 PM | #4 |
Mitchel should be able to do a 6-spline shaft since there stuff is all modification anyway. |
