Old 06-25-2018, 03:19 PM   #1
MGG
MGG's Avatar
Default Oil Canister Question
I have just purchased an 8BA oil filter canister from a fellow Ford Barner. It came with the required .060 inch inlet restrictor fitting and teed into it is another restrictor fitting which has a hole measuring about 3/32 inch diameter. Does anyone know what this 3/32 fitting is for? I have searched the threads and did not see any mention of this 3/32 inch fitting. Thanks
MGG is offline   Reply With Quote
Old 06-25-2018, 03:32 PM   #2
dakotafarmboy
dakotafarmboy's Avatar
Default Re: Oil Canister Question
I think it tees into the oil pressure sender
dakotafarmboy is offline   Reply With Quote
Old 06-25-2018, 04:20 PM   #3
fordwife
As I recall. the 52-53 mercurys [and maybe the 49-51 models] used this setup.
fordwife is offline   Reply With Quote
Old 06-25-2018, 05:35 PM   #4
MGG
MGG's Avatar
Makes sense. I guess that is better than having the sender down on the block?
