Old 05-11-2018, 01:41 PM   #1
johnbuckley
johnbuckley's Avatar
Default Early 21 inch wheel vs later 21 inch wheel
How can you tell if 21 inch wheel is the early ( AR) type or the later type? Can someone give me the width of the inner centre for the two types ?
johnbuckley is offline   Reply With Quote
Old 05-11-2018, 02:09 PM   #2
juke joint johnny
juke joint johnny's Avatar
Default Re: Early 21 inch wheel vs later 21 inch wheel
The bead outside of the lugnut holes is about 3/8 " on the later wheel .
on the early wheel it is about an inch.
Sorry I don't have an early wheel to measure
The AR used the same brake drums on the front and back
The AR front drum does not have a collar that goes right up to the bearing cone on the hub, instead it finishes about 2" from the center of the bearing cone
I hope this helps
Easy to spot the difference when you know what to look for
juke joint johnny is offline   Reply With Quote
Old 05-11-2018, 02:46 PM   #3
Great Lakes Greg
Great Lakes Greg's Avatar
The hub depth on an early wheel is an inch, and later wheels are about an inch and a half.
Great Lakes Greg is offline   Reply With Quote
Old 05-11-2018, 02:46 PM   #4
Ron in Quincy
Ron in Quincy's Avatar
Suggest you refer to the Service Bulletins; you do not want to put AR wheels on "B" drums or "B" wheels on AR drums.
Ron
Ron in Quincy is offline   Reply With Quote
Old 05-11-2018, 03:57 PM   #5
steve s
steve s's Avatar
Ron
I second this. I've seen bad things happen.
steve s is offline   Reply With Quote
Old 05-11-2018, 04:30 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Mix ups can cause inner wheel center hub cracks!!!
Bill Mixedup
"THE ASSISTANT GURU OF STUFF"
Old 05-12-2018, 09:08 PM   #7
Ronnie Lawson
Ronnie Lawson's Avatar
What is the definition for the AR 3.pdf
Ronnie Lawson is offline   Reply With Quote
Old 05-13-2018, 12:08 AM   #8
Floats
Floats's Avatar
Hi John,
I posted three photos.
The first is an AR rim and the next two are the later type.
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
