Old 12-29-2010, 05:38 AM   #1
JohnReb23
JohnReb23's Avatar
Default Cam Question
This may be a dumb question but I'lll ask anyway...
I have an 8BA in my car that was rebuilt by a previous owner. It's bored .60 over and has adjustable lifters. This got me thinking that maybe the cam was also altered or replaced during the rebuild.
So my question is this: how do I know figure out what kind of cam it is without any major disassembly?
I still have to run fuel lines and do a few more things before i can start the engine, but I'm a little curious anyway.
thanks, john.
JohnReb23 is offline   Reply With Quote
Old 12-29-2010, 06:38 AM   #2
JWL
Default Re: Cam Question
If you don't really care about the specifics of the cam you can extend the stem of a 2" travel dial indicator into the sparkplug hole and against the exhaust valve. If the valve travel is much more than around .300 the cam is probably not stock. Or, it must have hy-lift rocker arms.
If the specific timing/duration and lift numbers are important it will be necessary to get more aggresive with the tooling and disassembly.
JWL is offline   Reply With Quote
Old 12-29-2010, 07:31 AM   #3
Terry,OH
Terry,OH's Avatar
many of the aftermarket cams are marked on the front end where the distributor attaches.
Old 12-29-2010, 12:24 PM   #4
bbrocksr
Hy-lift rocker arms on a flathead?
bbrocksr is offline   Reply With Quote
Old 12-29-2010, 02:12 PM   #5
OLD...BILL
OLD...BILL's Avatar
Yes ( Hy-lift rocker arms ) this is something you get from that guy in england,that sell all that real neet flathead stuff. cheep. like new break fuild for manual breaks, for early Fords ...ect. ....OLD....BILL
OLD...BILL is offline   Reply With Quote
Old 12-29-2010, 02:47 PM   #6
OLD...BILL
OLD...BILL's Avatar
HEY JOHN: I haft to jump back in, and to your question. you know you have adjustable lifters, you must have had the intake off. at this point I would run a check of the adjustment ( setting ) of the lifters, and better way to check for lift of the cam, the travel of the lifter, as JWL said: a dial indicator, if the travel is more than .300 its not stock, ....Just a quick look at the lifters, in the bore, lets say one is down in the bore about 1/8" and next to it one up more than a 1/4 inch or so , using you best eye ball, its about 3/8 travel, it a hot cam... let us know what you find, .... OLD....BILL
Old 12-29-2010, 03:30 PM   #7
JohnReb23
JohnReb23's Avatar
I think i'll try to put a dial gauge into one of the spark plug holes. Removing a spark plug definitely fits my "no major dissasembly" request.
If it turns out to be a non-stocker, maybe i'll check for a stamp like Terry suggested.
Thanks, and i'll let you know what I find after i get back to the barn sometime this week.
john.
Old 12-30-2010, 01:17 AM   #8
BillM
BillM's Avatar
If you want to get into it in more detail you could do something like this:
My web page:
http://myplace.frontier.com/~wgmumaw/
BillM is offline   Reply With Quote
Old 12-30-2010, 08:46 AM   #9
Craig CT
Craig CT's Avatar
Hi John; If you can't reach the builder how about someone that knew him. If it has one carb and stock ignition it's probably stock or close to it. Think it through and you might find it's just as well to finish it and run it. If you like the performance you're good, if not you can change the cam later. Good luck, Craig.
Craig CT is offline   Reply With Quote
Old 12-30-2010, 02:00 PM   #10
Ol' Ron
Ol' Ron's Avatar
In the many years I've been working on flatheads, I have found adjustable lifters in many stock engines. back in the day, after a quick valve job a set of 12 dollar adj. lifters were used. hat's right. Back in the 40-50's they were pretty cheep. Not many back yard rebuilters ground the stems. At one time I had a dozen or so sets of adj lifters from junkyard engines.
Old 12-30-2010, 11:43 PM   #11
Flathead
Flathead's Avatar
Sometimes a set of adjustables was the only reward for tearing down a seized-up motor that turned out to be junk.
Flathead is offline   Reply With Quote
