04-24-2018, 03:59 PM | #1 |
Parking brake cable 1937
Hello,. Can I get some guidance on the routing of the park brake cable where it enters the body. Does it share the hole with the speedometer or some where else?
04-24-2018, 05:52 PM | #2 |
Re: Parking brake cable 1937
Hi,
The park brake cable is routed through the firewall (aka dash) in the area where the steering columns goes through. It goes under a bracket with a relief edge on it that is screwed down to the floorboard. The attached pdf should help. It is a little hard to see the cable, in my case I routed it along with some wires. gregg |
01-10-2019, 08:28 PM | #3 |
Gregg,
Thanks for the photos of the parking brake and speedometer cable routings for the 1937 model passenger cars. My car has both going through the hole in the firewall and I thought the speedometer cable was in the wrong place. Your information resolved the issue for me. Zeke |
01-10-2019, 10:42 PM | #4 | |
Glad to help out Zeke. In general, if you need some 37 info, good chance I can help. I have several in the restoration process and try to take pics and document along the way gregg |
