#1 |
i'm leaking coolant into the combustion chamber and crankcase of my '48 V8. Any cure?..or just keep driving it until? The leak is in the lifter valley around a lifter bore.
#2 |
Will need to be repaired. Magnaflux or something to fix the issue unless its beyond repair.
Sent from my SM-G955U using Tapatalk |
#3 |
Be afraid of 'Hydrolock' > https://www.quora.com/What-happens-w...is-hydrolocked
#4 |
I do not understand how such a leak would invade the combustion chamber?? However, there are some remarkable block sealer products which can stop most leakers. Except government workers.
#5 |
If you value your motor , I would repair or replace it before it is unrepairable , or at least much more expensive.
#6 |
happens. G.M.
www.fordcollector.com |
#7 |
pull the plugs out and check for water (rust or just really clean plug) will help to indicate if it is a head gasket. I made up a rig to put air pressure in the cylinders and this has helped find a few leaks
#8 |
zoite
#9 |
I've had good luck with block sealant in several engines.
