Old 04-14-2018, 06:46 AM   #1
spinelll
spinelll's Avatar
Default Horn Rod Lube?
Do you use dialectric grease or another type on the horn rod? My horn button sometimes turns when I move the steering wheel and as a result the lights turn off.
Thanks
Leo
spinelll is offline   Reply With Quote
Old 04-14-2018, 08:28 AM   #2
slammin
slammin's Avatar
Default Re: Horn Rod Lube?
When I installed a new horn/light rod in my 29, I put a little bearing grease around the top of the column where the light rod makes contact.
slammin is offline   Reply With Quote
Old 04-14-2018, 10:52 AM   #3
100IH
It's not always rubbing at the outside of horn rod tube, often the rub is the upper cast hub where the outer edge fits down in the recess of the wheel. Check the clearance here with a piece of paper in and around the crevice. Also there is a brass bushing that often gets left out at the very top of the rod and just under the hub for the horn.
100IH is offline   Reply With Quote
Old 04-14-2018, 01:39 PM   #4
spinelll
spinelll's Avatar
Are you referring to this? If I slip this on, the horn ring doesn't seat.
Old 04-14-2018, 03:15 PM   #5
SeaSlugs
SeaSlugs's Avatar
time to drill out the top of the steering rod - it gets squashed down when you tighten the steering wheel nut.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-14-2018, 05:30 PM   #6
Synchro909
Synchro909's Avatar
Back to lubricating the horn rod, I apply a small amount of powdered graphite. It can't dry out.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 04-15-2018, 04:45 AM   #7
Bruce of MN
Bruce of MN's Avatar
I can't visualize where to drill, can you clarify?
Bruce of MN is offline   Reply With Quote
Old 04-15-2018, 05:07 AM   #8
4port
4port's Avatar
Enlarge the inside diameter of the shaft, by running a drill bit down it for a few inches. Find a bit that fits the shaft hole, then get a bit 1/64" larger in diameter and enlarge the hole. Then test the horn rod for binding.
4port is offline   Reply With Quote
Old 04-15-2018, 05:35 AM   #9
canadian
I had a problem similar to yours, light switch rotating with wheel . I cleaned , lubricated , several times to know avail. found out that the lower spring never had enough compression when light switch and wiring harness was assembled to hold detents for light positions firm enough. replaced with new spring ... all good. does your light switch hold positive solid positions when turning light switch to various positions ... I think that thats a sign of a weak spring.
canadian is offline   Reply With Quote
Old 04-15-2018, 07:56 PM   #10
SeaSlugs
SeaSlugs's Avatar
Yup hes got it.
Old 04-15-2018, 08:52 PM   #11
1crosscut
1crosscut's Avatar
Could be that the switch/lever at the center of the steering column is not square with the tube and it's rubbing on the steering wheel. That was the problem with the last one I ran across that was moving with the steering wheel. Just gave it a bit of a tweak to straighten it out and all was well.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 04-17-2018, 09:40 AM   #12
Jerry in Shasta
Jerry in Shasta's Avatar
Try running a .38 or .45 caliber bore brush and WD40 down the shaft to clean the rust and junk out.
Just my W.A.G at the problem
JB
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 04-18-2018, 07:32 AM   #13
captndan
captndan's Avatar
If you use WD40 follow up with Vick’s.
captndan is offline   Reply With Quote
Old 04-18-2018, 08:13 AM   #14
Will N
Will N's Avatar
I would not recommend this, as taking any material out of the steering shaft might weaken it. Before I did this, I would reduce the diameter of the horn rod.
Will N is offline   Reply With Quote
Old 04-18-2018, 03:37 PM   #15
SeaSlugs
SeaSlugs's Avatar
Were not saying take an 1/8" off - just ever so slightly. The nut and taper portion does get squashed down over the years of people tightening that nut to probably way too tight, beating on it, using pullers, running a die down the threads, etc. Its probably in the top 1" its the issue. Horn rod is what 3/8" diameter? Run a 3/8" bit down the hole. if 3/8" is loose creep up to a W (.386") bit or 25/64 (.390").
Old 04-19-2018, 11:04 AM   #16
burner31
burner31's Avatar
For the lube I use the lite white grease, a little dab will do ya, does not get stiff in cold weather, stays wet/moist for a long time.
Hint: Make sure the rod is perfectly straight (they bend real easy)
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 04-19-2018, 08:03 PM   #17
Anteek29
Anteek29's Avatar
After straightening the slightly bowed rod I lubed it liberally with chassis grease and reassembled.
No more problems.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
