03-18-2018, 12:27 PM | #1 |
1936 roadster front seat question
Is a 36 roadster seat and a 36 3 window coupe seat the same? If not does someone have pictures of the seat pan and back for a roadster?
03-18-2018, 12:33 PM | #2 |
Re: 1936 roadster front seat question
I don't have photos, but those seats are totally different. I do have a new repo back cushion for a 36 roadster if interested.
03-18-2018, 07:28 PM | #3 |
Speedway, 35/36 roadsters did not have adjustable seats. The bottom seat frame sat on a wooden frame as shown below. It was trimmed as shown below. In the front corners of the frame were 2 metal pins that stuck up and fitted into a hole in each front corner of the seat bottom. You could remove the seat bottom and store tools etc. underneath, but no seat adjustment. The seat back frame was fixed in place and could not lift up like in a coupe. The gap between the seat bottom frame and seat back was filled with a metal plate(again shown below.
Hope this helps a little. Don |
03-18-2018, 08:33 PM | #4 |
Don and TJ Thanks for the info it would appear that my roadster has the correct seat. Any way to move the seat back for a little more leg room? I am 6'4", would not be opposed to cutting down the package tray/top boot to give me more room to slide the seat back a couple of inches. If I trimmed an inch or two off the side boards where it sticks off past the rear support board would that work to move the assembly back? This is my first roadster, was always able to move the seat a little on the 3 windows I have owned.
03-19-2018, 08:46 AM | #5 |
You could shorten the package shelf and also move the bottom cushion back on the seat riser. The other option is to use a seat from a late model SUV and mount it to your existing framing. I did this in my '41 pickup to give me more leg room. I did it without modifying the stock seat riser and it moved me down about 3' and back a little over 2". I know it's not stock, but it works and I didn't have to remove any stock components. Got the seat with nice upholstery at Pick-N-Pull for $50. You should be able to mount the seat on the existing (or new) plywood base where your old cushion now resides. If you remove the seat tracks on the new seat it will also lower you about another inch. Just an idea that may work for you.
03-19-2018, 10:00 AM | #6 |
03-19-2018, 01:26 PM | #7 |
Missing the metal side plate on my 35 need a better photo of it.. How does it attach? Could someone make a pattern of one and send it to me ? would pay for cost and shipping
Thanks |
