02-28-2018, 11:03 PM | #1 |
1931 RPU Reference Pictures
Im in the middle of a 1931 RPU, and need some reference pictures of the cab back bracing, wood, door jams and seat structure. So far I can find pictures of one brace, but none showing where they go, or if there are others. Any help would be appreciated.
Thank You, Daniel
Thank You, Daniel Nelson 1957 Ford Fairlane, and building a 1931 Ford Roadster Pickup. |
03-01-2018, 12:52 PM | #2 |
Re: 1931 RPU Reference Pictures
If you put your general location in your profile maybe someone that lives close will invite you over to look at and photograph theirs.
Charlie Stephens |
03-01-2018, 02:44 PM | #3 |
I don't recognize the part to the right in your first post. Is it a cowl top to be used when you remove the gas tank? See attached pictures. The photos are reduced resolution for posting. Send me your email if you would like full resolution copies. Let me know if there are any other photos you want. Still waiting for your general location.
Charlie Stephens Last edited by Charlie Stephens; 03-01-2018 at 03:05 PM. |
03-02-2018, 09:43 PM | #4 |
I saw. A slick set up they made a block conture to back of cab and bolted from bed side with carage bolts nuts on in side of cab would make real solid back gona do that on mine
03-03-2018, 03:45 PM | #5 |
The top bolt for the wood attaches to the body with a carriage bolt that has the head on the outside. The bottom attaches to the seat riser pan. The clip closest to the top of the picture holds of the bottom of the rear seat.
Charlie Stephens Last edited by Charlie Stephens; 03-03-2018 at 05:27 PM. |
04-25-2018, 10:57 PM | #6 |
