Old 02-22-2018, 03:06 PM   #1
fordor
Default 60 hp waterpump fitment
I can't get the waterpump to seat against the outer gasket. I rebuilt the pump and replaced the rubber inner seal. I don't know why this won't tighten up.
See attached photo.
I have cleaned the housing and even have tried a nos pump with the same result. Any suggestions would be appreciated. This is the straight pumps from a 38 ford.
fordor is offline   Reply With Quote
Old 02-22-2018, 03:37 PM   #2
fordor
Default Re: 60 hp waterpump fitment
Can't seem to load pic.��
Old 02-22-2018, 05:42 PM   #3
Bulligen
Bulligen's Avatar
Do you think you might have mixed matched the tapered housing to the straight pumps?
Bulligen is offline   Reply With Quote
Old 02-22-2018, 06:47 PM   #4
fordor
No, I have the right housing. I have a 37 housing also(tapered). I can tell the difference.
Old 02-22-2018, 08:39 PM   #5
T Scott
Those tapered housings tend to corrode in the seal area and sometimes with deep pitting. I sand blasted mine and filled the pits with JB Weld. Smoothed everything up and got a good seal.
T Scott is offline   Reply With Quote
Old 02-22-2018, 09:37 PM   #6
JSeery
JSeery's Avatar
Want me to load it for you?
Old 02-23-2018, 09:41 AM   #7
fordor
If you would. I'll be ail it to you.
Thanks
Old 02-23-2018, 09:46 AM   #8
fordor
So how do I email it to you? I don't see where I can send an attachment or pic from my photos.
Old 02-23-2018, 05:44 PM   #9
JSeery
JSeery's Avatar
fordor wanted me to post a photo for him. Not sure which way you wanted it turned.
Old 02-23-2018, 09:47 PM   #10
Bulligen
Bulligen's Avatar
Are you using a flathead 60 waterpump tool to tighten it ?
Old 02-23-2018, 09:52 PM   #11
fordor
Yes I have the proper spanner wrench. Still end up with the same gap.
Old 02-24-2018, 05:58 PM   #12
3738
3738's Avatar
I had a similar situation 22 years ago on my 37 Tudor 60 hp. I could not get the water pump to seat down tight against the housing. I put (2) of the copper washers between the pump and the housing, tightened it down and 22 years later, still no leaks.
3738 is offline   Reply With Quote
Old 02-24-2018, 07:05 PM   #13
fordor
Yea, I guess I'm going to have to double up the gasket and see what happens.
