Old 02-22-2018, 10:46 AM   #1
Leatherback 57
Leatherback 57's Avatar
Default Wishbone ball
My wishbone came loose on my 29 causing a shimmy. Found that one of the nuts had cracked. When taking apart it had the rubber ball cap assy that was worn out. Also the felt pad was up inside. I ordered new assy from snyders with the felt. What is proper way to install rubber on ball and how is felt installed or is it nessesary with rubber style?
Leatherback 57 is offline   Reply With Quote
Old 02-22-2018, 10:53 AM   #2
daveymc29
daveymc29's Avatar
Default Re: Wishbone ball
I squirt some WD-40 into the ball and push it onto the ball. I don't use the felt. Works for me though there are a number of folks that condemn the rubber ball as not proper and doesn't work. They advocate building up or replacing the ball and use only the original set up. Works for them.
daveymc29 is offline   Reply With Quote
Old 02-22-2018, 10:57 AM   #3
Gary WA
Gary WA's Avatar
Rubber ball is a fix,should replace ball by welding and reshaping to proper size.felts for lubrication.
www.whidbeymodelaclub.com
Old 02-22-2018, 11:06 AM   #4
WHN
How is the rest of your front end?
Shimmy could be a combination of worn parts.
If you have not rebuilt front end and you decide to remove wishbone, that’s the time to get things sorted out. Enjoy.
WHN is offline   Reply With Quote
Old 02-22-2018, 11:19 AM   #5
Leatherback 57
My front end has all been rebuilt. My ball looks to be in good shape but has rubber ball cover installed and was worn out. Is there spec diameter for original ball? If good I'll go back to original. I set toe in to 1/16. Was at 3/8 toe out!!!
Old 02-22-2018, 11:53 AM   #6
WHN
A lot of guys do not like the rubber ball. Having said that. If just replacing the rubber ball will get you back to where you want to be? That sounds like the best thing to do. Will most likely last for a good number of years.
If it isn’t broken, don’t fix it.
Old 02-22-2018, 12:06 PM   #7
gearloose
gearloose's Avatar
What is the spec diameter for the original ball? Be a good thing to know so you know what needs to be done, other than that you are guessing.
gearloose is offline   Reply With Quote
Old 02-22-2018, 12:36 PM   #8
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
This article might be of interest.
http://cedarcreekas.org/TechTopics/RadiusBallRandR.pdf
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 02-22-2018, 12:37 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Some just use the CUPPED shaped spacer washer & NO RUBBER BALL. Suppliers sell them. QUICK & EASY job.
Bill Tight
"THE ASSISTANT GURU OF STUFF"
Old 02-22-2018, 02:54 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
The ball is 1 1/2".
My 29 had the rubber cover, so I removed the rubber and cast iron caps, and installed the original style steel caps. I still had at least 1/8" gap between the caps, so it was fine.
Old 02-22-2018, 04:11 PM   #11
Synchro909
Synchro909's Avatar
When one of my cars started to shimmy, I checked things over and found amongst other things that the wishbone ball was badly worn. I put in one of those cupped washers and all was good there - for a while. I later found that the washer had slipped from the top of the ball to now being under it. I threw it away and built up the ball with weld and reshaped it with a flap disc and 1 1/2" washer I made. All has been good for about 20,000 miles since.
I see the rubber ball and cupped washer as stop gap, temporary repairs. Fix it right, fix it once.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 02-22-2018, 07:49 PM   #12
gearloose
gearloose's Avatar
Originally Posted by Tom Wesenberg View Post
The ball is 1 1/2".
My radius ball measured 1.479. I have been using the original style so maybe I will add the washer and see how the bolts tighten up.
Old 02-22-2018, 11:29 PM   #13
sjhark
sjhark's Avatar
Does the washer go on the top or the bottom of the ball?
If earthworms had machine guns, we'd all be in trouble!
sjhark is offline   Reply With Quote
Old 02-23-2018, 08:00 AM   #14
daren007
Install the felt above the ball inside the bell housing. Hold in place with the pin through it.
daren007 is offline   Reply With Quote
Old 02-23-2018, 10:44 AM   #15
100IH
sjhark, I say on top because that positions the axle for more caster. Under would be less caster like a model T and more apt to wobble or shimmy.
100IH is offline   Reply With Quote
Old 02-23-2018, 12:04 PM   #16
Leatherback 57
My ball measures 1.4960and 1.4955. Is that ok to use original type assy?
Old 02-23-2018, 01:04 PM   #17
Russ/40
Russ/40's Avatar
Assuming your two measurements are in horizontal and vertical planes, your ball is very round. Sounds great.
Russ/40 is offline   Reply With Quote
Old 02-23-2018, 05:44 PM   #18
sjhark
sjhark's Avatar
Thank you, 100IH! That was exactly why I was asking.
Old 02-24-2018, 02:59 AM   #19
Tom Wesenberg
That's as good as a new part.
Old 02-27-2018, 02:00 AM   #20
dave in australia
This was how I repaired mine.
https://www.fordbarn.com/forum/showthread.php?t=143140
dave in australia is offline   Reply With Quote
