Old 02-22-2018, 08:39 AM   #1
Fast31
Default Transmission case repair
I had a 1931 gearbox housing with a worn down cluster gear boss. I made a grinding/lapping tool to grind the surface flat and smooth again. I ground the boss back to accept a 1928 thrust washer. Henry skipped those and made the bosses taller at the end of 1928 to cut on cost. Luckily these washers are still available. I worked to get a cluster gear end play of .005” - .017” as per Van Pelt’s Transmission Book. I glued sand paper onto the lapping tool, one on each side, started with 60 grid, followed by 80 and finished with 120. I made a little video to show the details. Check my channel 29FastFord or the link below.
https://youtu.be/dLPqmao-GlM
File Type: jpg A0BA4295-CE42-497E-AED6-0D87E8CABFA6.jpg (63.1 KB, 183 views)
Fast31 is offline   Reply With Quote
Old 02-22-2018, 08:58 AM   #2
JBill
Default Re: Transmission case repair
Very clever! Fun video to watch. You're quite a craftsman. Well done!
JBill is offline   Reply With Quote
Old 02-22-2018, 09:07 AM   #3
Fast31
Thank you! The fun part is probably my accent ;-).
Old 02-22-2018, 09:25 AM   #4
jhowes
Interesting, where does one find the measuring tools that are needed for so many things when working on a car? I have some that I found on ebay but generally I don't know what the tool is called, like his inside caliper set. Jackdumb
jhowes is offline   Reply With Quote
Old 02-22-2018, 09:28 AM   #5
Fhane
Fhane's Avatar
Very good. Thanks
Fhane is offline   Reply With Quote
Old 02-22-2018, 01:41 PM   #6
Fast31
Telescoping gauge kit. We have several tool webshops in The Netherlands. I regularly scroll through these webshops, just to look what’s available.
Old 02-22-2018, 02:44 PM   #7
Russ/40
Russ/40's Avatar
So happy to see your post and video. I'm a real fan of doing it yourself. Your solution shows how a little ingenuity and the job can be done without a machine shop. I did something similar on my case. Your solution is far more elegant than mine was. Great post.
Russ/40 is offline   Reply With Quote
Old 02-22-2018, 04:09 PM   #8
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Did you make the bearings for the tool as well? Very nice.
Old 02-23-2018, 06:40 AM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Fast31,
I'm surely AMAZED by your skills & ingenuity! GREAT Camera skills, also!
Can't even imagine how many hours it took???
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 02-24-2018, 04:28 AM   #10
Fast31
Originally Posted by BILL WILLIAMSON View Post
Fast31,
Bill W.
Bill, it took me one evening to machine the shaft, lapping disk and the 2 bearings. The cast iron grinds away pretty easy, but so does the sandpaper. So I had to cut off and glue on sandpaper several times. Waiting for the glue to cure took the longest time (and patience).
For me a large part of the Model A hobby is to find or to think up, design and build special tools to do the job right.
Old 02-24-2018, 11:33 AM   #11
BILL WILLIAMSON
Fast31,
You're a DEDICATED Man, keep it up!
Find Markus Maurers' website in Zurich, Switzerland, he's made up MANY special tools & fixtures, while restoring his Grandfathers' '29, extended wheelbase, flatbed "A", with a special cab, built by some well known builder there.---There's HOURS & HOURS of GREAT info on his site. The Dog & I communicate with him, OFTEN. He posts GREAT step by step photos of his 14 Year restoration, including very PRECISE INFO/DRAWINGS/DIMENSIONS/ETC, of all the tools & fixtures he builds! Markus should get an "AWARD" for his camera skills, at least.
Bill W.
Old 02-25-2018, 08:41 PM   #12
glenn in camino
glenn in camino's Avatar
Interesting, but there are lots of used good ones at swap meets.
glenn in camino is offline   Reply With Quote
Old 02-25-2018, 10:28 PM   #13
Cape Codder
Cape Codder's Avatar
Bill,
So how do I find this Markus Maurers website?
Cape Codder is offline   Reply With Quote
Old 02-25-2018, 11:25 PM   #14
RUNNERBUN
RUNNERBUN's Avatar
Yes, there might be, but where is the self satisfaction of having solved the problem with your own ingenuity, design and skill.
I say congratulations and well done and thanks for sharing.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 02-26-2018, 11:20 AM   #15
JBill
Might not be so many swap meets in the Netherlands, where the poster is located.
Old 02-26-2018, 03:02 PM   #16
Fast31
You are so right!
