Old 02-21-2018, 12:30 AM   #1
Chris Haynes
Chris Haynes's Avatar
Default Powering a GPS with 6 volt.
Months ago I read about a device to let you use 12 Volt negative ground GPS and Power Port with a 6 volt positive ground system. But now searching I can't find it. Any leads? TIA
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 02-21-2018, 12:47 AM   #2
cw253748
cw253748's Avatar
Default Re: Powering a GPS with 6 volt.
Look on eBay for a buck booster converterhttps://www.ebay.com/itm/DC-DC-Current-Boost-Buck-Converter-Power-Voltage-Regulator-6-35V-to-1-35V-5A/321795754199?epid=1248563814&hash=item4aec8588d7:g :qJ0AAOSw9N1Vke8D
cw253748 is offline   Reply With Quote
Old 02-21-2018, 01:01 AM   #3
KenCoupe
KenCoupe's Avatar
Both Snyders and Brattons (and probably other suppliers) have two things that could be used. First is a power converter/inverter that converts 6-volt positive ground systems power to 12-volt negative ground.
The other item is a USB Charging port which has two USB charging ports and can be used with either 6 or 12 volt. The USB charging port will need a power source such as the A-Plate sold by the vendors or other power such as a "cigarette lighter" type receptacle.
Search the vendor's web sites for the correct part numbers.
Also, Tom Endy has a tech article on the Santa Anita A's web site or the Jan-Feb 2009 Restorer on how to make a setup for the power inverter.
Ken
KenCoupe is offline   Reply With Quote
Old 02-21-2018, 01:42 AM   #4
Chris Haynes
Thanks guys.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-21-2018, 02:01 AM   #5
MVal
A couple of years ago Tom Wesenberg posted an article how to wire a cigar lighter to be an outlet for a cell phone charger or something similar. Charger output for the cell phone was only 5 volts negative ground as I recall and think the GPS is the same. Might use the search function and look for some of his posts or maybe "cell phone charger" or some similar wording.
Al
MVal is offline   Reply With Quote
Old 02-21-2018, 02:07 AM   #6
MVal
Search "cell phone charger" and there are several ideas there although I didn't see Tom's post.
Old 02-21-2018, 02:07 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
This is what I use to run my phone and GPS, both will charge fine on 6 volts. Just cut the plug off and ground the positive wire, and run the negative wire to any convenient power terminal.
https://www.ebay.com/itm/25334309301...MakeTrack=true
Old 02-21-2018, 02:37 AM   #8
Tom Endy
Tom Endy's Avatar
See attached article
Tom Endy
File Type: pdf 1D-Power inverter (Restorer Jan-Feb 2009).pdf (663.2 KB, 228 views)
Tom Endy is offline   Reply With Quote
Old 02-21-2018, 04:53 AM   #9
Reconnoiter
I used one of these converters....works great. Installed it hidden behind left lower cowl panel and attached a cigarette lighter socket outlet and ran it to the passenger side under the dash. Under $20 in Amazon...
https://www.amazon.com/KNACRO-Conver...120w+6v+to+12v
I was originally guided to it when I read this thread:
https://www.fordbarn.com/forum/showt...light=Inverter
Good luck!
Reconnoiter is offline   Reply With Quote
Old 02-21-2018, 06:37 AM   #10
AL in NY
AL in NY's Avatar
I use a TomTom in my CCPU on 6 volts and it works great. If your GPS plugs into a USB port(5 volts), it will work on 6 volts. They usually have a GPS cigarette lighter power supply which has a voltage regulator circuit in it to keep the output voltage to the GPS unit constant at 5 volts. You just need to wire a cigarette lighter with the negative for the case and the positive to the center contact. With the case wired to negative, you have to insulate it from the Model A's positive ground when you mount it.
AL in NY
AL in NY is offline   Reply With Quote
Old 02-21-2018, 09:34 AM   #11
SeaSlugs
SeaSlugs's Avatar
Yup - spot on and what i was gonna say haha.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-21-2018, 03:21 PM   #12
Chris Haynes
Thanks to all for the ideas.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 02-21-2018, 05:41 PM   #13
w.michael
w.michael's Avatar
My Garmin works great on 6-volt positive ground Model A. Just be sure you reverse the polarity on the socket. I have run it for several years with no problem.
W. Michael
w.michael is offline   Reply With Quote
Old 02-21-2018, 06:58 PM   #14
antiquepa
antiquepa's Avatar
Post number 9, by Recounditon is the way to go, i also bought mine on amazon and put in a 39 chevy. i would suggest to run it directly off the battery and to fuse it, that way you will have it connected right to work with any GPS or 12 volt device. This will work on any 6 volt system and if you come from the battery you will know pos, neg wires will be connected right.
antiquepa is offline   Reply With Quote
Old 02-22-2018, 07:34 PM   #15
Fred K-OR
Fred K-OR's Avatar
Good luck!
I also used one of the power converters. And after burning out two plugs for the GPS, I realized what I did. Remember the Model A is a positive ground and the 12 volt systems are negative. I learned the hard way! Hook it up to accommodate this situation.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 02-23-2018, 02:59 AM   #16
burner31
burner31's Avatar
$10 at walmart is all it takes, can run a GPS, charge the phone, change my bluetooth speaker with no problems, and easy to hook up, only two wires.
12V or 6v...doesn't matter. It's not the volts you need concern yourself with...it's the amps, and a 6 volt will handle that with ease.
Can even get one with a cigerette lighter if you like
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 02-23-2018, 07:16 AM   #17
old31
Burner, do you have a part# or pic?
Old 02-23-2018, 12:29 PM   #18
Fred K-OR
Fred K-OR's Avatar
Just be sure those "two wires" are hooked up to the correct polarity!
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 02-23-2018, 12:50 PM   #19
burner31
burner31's Avatar
I'll send a pic of my set up as soon as I get back there
Keith
Shawnee OK
'31 SW 160-B
Old 02-23-2018, 01:03 PM   #20
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Those low cost converters work good, except for a cb radio. When you ground the antenna, things go south. The two grounds don't like each other. Maybe if I isolate the antenna base??? Most everyone in our club use a CB.
Jacksonlll is offline   Reply With Quote
