02-09-2018, 05:35 PM | #1 |
Leaky valves
After lapping the valves/seats and segmenting my pulley in 4 equal sections to correspond with TDC on all cylinders the leaking valves have gotten worse when I re-did the leak down test.....way worse! With intake manifold off it was very easy to identify leaking intake valves, would having intake manifold and carb.off exacerbate the condition? Bottom line, if piston is at TDC, both valves on their seats and valve stems not making contact with the lifters I should have very little leakage? On an earlier post Ol'Ron suggested to look for "overlap split" on intake and exhaust valves but already had heads on, would this be worth doing at this point?
02-09-2018, 05:40 PM | #2 |
Re: Leaky valves
Do you have the piston at the "right" TDC?
You get two TDCs for each turn of the cam. You need the firing TDC where both valves are closed. For each cylinder identify the TDC where the valves are one just closing and one just opening. Now rotate the crank one whole turn until back at TDC. That is the one you want. Mart. |
02-09-2018, 06:22 PM | #3 |
Re: Leaky valves
The intake manifold and carburetor have nothing to do with the valves sealing. If both valves are closed and the stems are off the lifters, you are on TDC firing. What Ron said has nothing to do with setting the valves. That position is not for setting the valves.
02-09-2018, 07:20 PM | #4 |
Re: Leaky valves
And of course you have correctly set the valve to lifter clearance ??
02-09-2018, 07:32 PM | #5 |
Re: Leaky valves
If both valves are not touching the lifters AND no sticking or bent valves , or broken valve springs , you should have very little air flow . Also check with a vacuum line to your ear to see if intake , exhaust or crankcase .
02-09-2018, 07:55 PM | #6 |
Re: Leaky valves
Thanks for the help guys. |
02-10-2018, 05:12 AM | #7 |
Re: Leaky valves
Valve seats may not be concentric or angled correctly. I had trouble with this when I cut mine by hand with a special cutter. I had a custom pilot machined to go down through the valve guide and that solved the problem. It took a lot of time to cut the 3 angles and to get the proper margin size and it's location on the valve face
02-10-2018, 10:10 AM | #8 |
Re: Leaky valves
How was the valve job done. Stones or cutters. Also what pilot system.
R |
02-10-2018, 01:00 PM | #9 |
Re: Leaky valves
Am beginning to think when the machine shop did the valve job it was done incorrectly; as to how it was done I have no idea, it was done over 20 years ago. The engine has fewer than 500 miles on it and when it was in the car I thought it ran quite well even though it suffered from low compression from the very beginning. I replaced it with a 276 and never looked back. Been sitting in the corner of the garage for years and finally decided to sell it but don't want to sell it to someone when I know theres something wrong with it.
After lapping the valves I thought problem would be solved, but if anything I made the problem worse. |
02-10-2018, 02:15 PM | #10 |
Re: Leaky valves
What is you wet cranking compression ?
02-10-2018, 02:46 PM | #11 |
Re: Leaky valves
oil on the rings and 12V'S 70-80 lbs.
02-10-2018, 04:26 PM | #12 |
Re: Leaky valves
And dry is near that ? What I'm trying to understand if it's just leaking thru the valves or valves and rings . If the valves were the the only problem , it's minor compared to rings and valves . It would still be a good item to sell as long as the buyer understands the issue .
02-10-2018, 04:37 PM | #13 |
Re: Leaky valves
If you laped the valves you should know what condition they were in. When you lap them you are looking for things like seat width and if there is full contact on both the valve and seat.
02-10-2018, 04:57 PM | #14 |
Re: Leaky valves
your wet and dry test has already answerd your question. little change between the two means your rings are fine.If you can run the engine it might hammer the valves in a bit there maybe some residue from the lapping process causing the issue. I would double check that you have valve clearance as this is the most likely cause.
02-10-2018, 05:45 PM | #15 |
Re: Leaky valves
Does the engine have 2 piece guides
R |
02-10-2018, 05:47 PM | #16 |
Re: Leaky valves
>>>I thought it ran quite well>>>I replaced it with a 276 and never looked back.>>>
And does your 276 measure up to its expected numbers using your same test techniques? Jack E/NJ |
02-10-2018, 08:15 PM | #17 |
Re: Leaky valves
They should not be leaking when they're fully closed and not touching the tappets. It sounds to me like whomever did the valve job - didn't do it correctly and/or may have had the incorrect tools/mandrels to do the job (causing incorrectly centered seats, etc).
Even with the earlier split guides, when I used to build my early racing engines I would pour lacquer thinner into the intake ports (during the valve setup process) and insure that there was no visible "weeping" of the thinner around the valve. If any valve leaked the slightest amount - out it came to resolve the problem. |
02-10-2018, 11:46 PM | #18 |
Re: Leaky valves
One piece guides. The 276 has excellent compression and never did a leak down test on it.
After laping the valves, valve bottom and seat had nice uniform gray surface all the way around. Valves are set go/no go method at .011 on intake and .013 exhaust. Regardless of the lash, if stems aren't making contact with lifters and valve components are good I should have very little leakage. Next step is off to machine shop out of area to re-do inserts and valves. |
02-10-2018, 11:54 PM | #19 |
Re: Leaky valves
if you used a marker pen while laping, it should have shown the contact area, which you said you did, and it showed good. if thats true, the only thing that can be wrong is you are adjusting the lash at the wrong time on the cam. forget the machine shop, and study up the correct sequence to adjust valves
02-11-2018, 04:52 AM | #20 |
Re: Leaky valves
If visual check shows uniform grey surface and the gaps are correct, with respect to a leak down test I'd trust my eyes and judgement better than the results. there may be a problem with the equipment of test method.
If the valves have passed visual inspection, have been hand lapped, seats are visually good, and gaps set correctly, and results are low after a dray and wet compression test, I would be wondering about cam timing. Can't give you a magic bullet reply, but I think you have done everything you can to rule the valves out. So, we have to ask ourselves, "What else could it be"? Is there anybody in your area that might be able to pay a visit and get a fresh pair of eyes on it? Mart. |
